Old 12-28-2007, 07:01 PM   #1
alta825's Avatar
285/75 16's or 305/70 16's - what should i get??
Pretty much settled on the Toyo M/T's and I'm torn as far as width. Do I stay w/ what I have - 285/75 16 or do I go a tad wider w/ the 305/70 16's?
FYI, even though I live here in the mtns of UT, snow isn't really a concern as it is not a winter rig, too much salt and lousy drivers out here. Mostly is a spring/summer/fall rig on FS roads w/ a bunch of washboard, w/ the very occsasional winter road trip up to Jackson Hole.
Will the 305's fit on a Quigley w/ the Baja 16x8 rims SMB spec's?
The 285's are rated at 3700+lbs while the 305's are 3500+lbs, both still higher than my current BFG AT's which are about 3400+lbs, so either should be an upgrade, cost is w/in a few $$
Thoughts anyone???
thanks
-d
2002 EB51 7.3L w/ Stage 2- UJoint 6" 4x4 Conversion
2001 RB50 V10 Quigley- SOLD
alta825 is offline   Reply With Quote
Old 12-29-2007, 01:19 AM   #2
285 vs 305 tires
Good choice. I think Toyo M/Ts are much better than BFGs. I think both sizes are the same height... I would go with the 285s. I like the 3700 lbs rating.. I have 295 70 17 that have 3970 lbs.
JM
2006 Sportsmobile PSD-----69 Jeepster----BMW1200GS---450 KTM----450YFZ--- 2007 F150----2005 Nissan
myriadmyriad is offline   Reply With Quote
Old 01-28-2008, 08:24 PM   #3
For what it's worth, I think I have decided on going with 285 75 R 17's on my 4x4 conversion. oclv
oclv is offline   Reply With Quote
Old 01-29-2008, 06:59 AM   #4
alta825's Avatar
well, I finally went for the Toyo MT's in the stock 285/75 16's. Man talk about BEEF! The van has a totally new look to it and the ride is on par w/ the BFG's and te noise really isnt any worse.
? regarding tire pressure - should I run the same as the D rated BFG AT's I took off? The MT's are 'E' rated...
-d
