Old 03-30-2017, 09:26 AM   #21
skyrat's Avatar
Originally Posted by Shaggy View Post
Any updates on this thread? I'm considering 4.56 on 14 350 eb 5.4 v8 W/33
I have a 5.4L v8.
I did a conversion with Agile Off-Road.
Started with a stock 3.73 LS and stock rubber.
Ramsey suggested the 4.10 with the BFG All-Terrain T/A KO2 LT285/75R16 I had already chosen. They are just under 33" at 32.8". Same shift points as stock. LOVE IT after two years of mostly highway, but over 1000 miles off road. IMHO 4.56 is pretty low unless you want a primarily off road vehicle. I still pull all the grades (I go over the Conway summit from Bridegport, CA at 65 in cruise control) with plenty of power. Soooo glad I did the 4.10.
George ><>
2005 5.4L E250 RB50 4x4 SMB
2000 4Runner Limited 4WD
But God demonstrates his own love for us in this: While we were still sinners, Christ died for us. Romans 5:8
skyrat is offline   Reply With Quote
Old 03-30-2017, 03:17 PM   #22
Shaggy's Avatar
skyrat its pretty hard to argue with anything that Ramsey ever said..... You ever pull anything heavy with it?
2014 E350 EB Quigley 4X4 [HOONIVAN]
2014 FJ Cruiser
Shaggy is offline   Reply With Quote
Old 03-30-2017, 10:05 PM   #23
skyrat's Avatar
No I have not. If I had to tow a bunch I might go a different way. If I had heavy towing regularly I would go for a v10 or diesel if my wife could stand the smell.
George ><>
Old 03-30-2017, 10:44 PM   #24
Jsweezy's Avatar
I have a v8 now and am planning on going with 4.30s. Main reason is because newer F250s come with 4.30s stock so thats gonna save me money by not having to have the axles regeared.
But also because if I go with 33s it will be killer for towing and if I decide to make a jump to 35s later it won't be an issue.
Old 06-18-2023, 06:51 AM   #25
martinli's Avatar
Originally Posted by campervanbeethoven View Post
Update...Went w/ the 4.56s.--- Picked up the van on tues. and just got back from a short trip to Glenwood Springs. Here are my first impressions.
The van is much better on the hills for sure. Going up to the Eisenhower tunnel from Denver we pulled the whole grade, without issue, at the posted speed limit. Vail pass was still a little steep for the 5.4, but we kept up with traffic for the most part. On the interstate I've lost the ability to cruise at 75 comfortably, although short bursts up to 75 and higher are doable, 60-65 seems to be where the van likes to cruise now in OD. Around town and on the "B" roads is where the new ratio really shines. Good passing and merging power and a whole lot snapier off the line. Haven't had the van off road yet but I did drive a little in low range and this thing really creeps along nicely. Can't wait to tackle some jeep trails around the neighborhood this weekend.
All in all I'm glad I went with the 4.56s over the 4.10s, although, I think the the 4.56s are probably better suited for a 35" tire. If your running 33" tires and can put up with the lack of high speed interstate cruising and are thinking of going to 35" tires in the future, then go w/ the 4.56s. If your happy w/ your 33s, then go with 4.10s.
On a side note, when they got the rear diff apart they found the remnances of a ford lsd in there. It was not working and the clutches were eating into the carrier. They fixed it all up and now Ive got both rear tires getting power. Ye haw!
Thanks again for the input...Luke
You say "On the interstate I've lost the ability to cruise at 75".
I assume engine RPMs got too high and it gets to noisy. Or is it something else that you mean? What RPMs do you get going 75?
Cheers Martin
martinli is offline   Reply With Quote
Old 06-18-2023, 08:31 AM   #26
Posting my rpms with 35s and 4.56 for the sake of completeness.
Curious to see the comparison to 33s
Old 06-19-2023, 01:18 AM   #27
martinli's Avatar
@E350 yes I already saw your posting and your figures.
Using the calculator from here : Gear Ratio Calculator
You should have 77 mph -> 2387 RPM
and with 33" tires it should be 77 mph -> 2515 RPM.
E350 - 2014 - 2WD
