Old 08-30-2013, 09:35 AM   #11
deserteagle56's Avatar
Re: A spare spare
Another option is an all around smaller wheel/tire for emergency use. You wouldn't want to use on a limited slip axle or a full time locker, but it could get you out of trouble when used on an open axle.
Worst case, you pull a front tire off and put the small spare on the front and swap the good front tire to the limited slip rear.
This has been my solution in the past. I carry two spares - a full size on the rear carrier and a LT245/70R17 in the stock location - and there were times I was glad I did! Seems like it's a rear that goes flat 90% of the time. With some practice (and two jacks) it doesn't take too long to swap a front to the rear and put that dinky tire on the front. But I also carry an extensive flat repair kit and have been able to put at least a temporary fix on most of my flats so I didn't have to change it at all.
Worshipper of Wild Country
deserteagle56 is offline   Reply With Quote
Old 09-25-2013, 07:45 PM   #12
Re: A spare spare
That's what I have as well, full size on the back, and another in the stock location. I haven't had to use either one since I've upgraded to Toyo Open Country MT's however....
Pete is offline   Reply With Quote
Old 09-26-2013, 09:00 AM   #13
yvrr's Avatar
Re: A spare spare
Same here. I have a "tire plug" kit which I used in Mexico for a sidewalk puncture that was still holding when we returned a thousand miles later. I also have an "old-fashioned" tire repair kit with the patch which goes inside the tire. You need to remove the tire at least partially for this type of repair so I have some tire irons for that task. To re-inflate a radial you need to either shoot starter fluid into the tire and light it or (my choice) carry a ratchet-type load restrainer to tighten the tire to the rim to start inflating it.
In addition to an air compressor, I have a 10-ton hydraulic jack and a Hi-Lift jack. I carry an Off Road base for the Hi-Lift (to spread the load of the jack if the ground is soft) and a Lift-Mate which gives a better grip on a bumper. My winch bag includes a chain which allows me, if needed, to chain the axle to the frame so the axle goes up with the body when using the Hi-Lift.
Yes, Hi-Lift jacks can be dangerous but if the flat tire is in a rut, you aren't going to get a bottle jack under the axle. The Off Road base helps stabilize the jack so it doesn't tip over and the Lift-Mate ensures that the bumper doesn't slide off the jack. Chaining the axle so you don't need to lift the body so high and being careful while jacking all helps minimize potential problems.
Jack
'01 Ford EB50p Quigley 4WD
Old 09-26-2013, 09:25 PM   #14
E350's Avatar
Re: A spare spare
yvrr: Awesome post for this thread. Thank you!
DADDOZR
REDOVAL
VanBo
Mike Ponce
