Old 07-14-2017, 10:26 AM   #1
Jeffrey's Avatar
Atlas 2sp xfer case output bearings
I have a 2007 E-350 SMB 4x4 with the Atlas 2sp transfer case. Noticed a bit of side play wobble at the front drive output shaft. Talking to Advance Adapters, they say to drop the drive shaft and check the big yoke nut first. Then move on to replacing the bearing and seal which can be done externally without removing the unit. Anyone here ever perform this procedure?
Old 07-14-2017, 02:02 PM   #2
I've swapped the seal out which wasn't bad. I think I used a 3" piece of pvc pipe to drive the new seal in. Didn't mess with the bearing.
Sent from my SM-G930V using Tapatalk
2006 EB Transformer
scummy is offline   Reply With Quote
Old 07-21-2017, 01:57 PM   #3
Jeffrey's Avatar
It turns out I may not have to mess with the bearing, unless it is deemed toast. While rocking the yoke slightly, we noticed that the nut on the output shaft was staying still, and there was no leak at the seal there. So we think the issue is the yoke, which is a welcome relief. Let's see it that's rue when we drop the shaft and remove the yoke.
Malbec
brushogger
MCSporty
MSD
