Old 01-05-2009, 05:37 PM   #1
Atlas Transfer Case fluid
I noticed a little less fluid in the sight tube at 6k, and topped it off some, then at 14k saw that is was again lower. Is this normal, just like motor oil, some fluid loss over the miles due to the heat?
I am planning on the getting the top-off kit from Atlas at the recommended mileage but just wondering about the lowering in the sight tube, Normal?
07 E-350
patrick51 is offline   Reply With Quote
Old 01-05-2009, 11:33 PM   #2
I never saw any loss until the rear seal started to leak. Not much on the pavement because the drive shaft was throwing it on the extreme air heat sheild and the exhaust plus all the dust absorbed it a bit. Actually I smelled the fluid burning on the exhaust. After washing it down I could see the fluid starting to drip a bit on the ground. That seal has gone twice in 42K.
Dave.
Old 01-06-2009, 06:00 AM   #3
Re: Atlas Transfer Case fluid
Haven't noticed any change in mine, over the +/- 12,000 miles since I've owned it.
BTW, what's the "top-off kit"?
Old 01-06-2009, 09:28 AM   #4
Atlas transfer case fluid
The top off kit I referred to is the fluid provided by atlas for the recommeded change at I believe 20k miles, it is listed in the atlas users manual.
07 E-350
Old 01-06-2009, 10:18 AM   #5
jlrray's Avatar
Send a message via ICQ to jlrray Send a message via AIM to jlrray Send a message via MSN to jlrray Send a message via Yahoo to jlrray
I didn't even know there was a sight gauge...
jlrray is offline   Reply With Quote
Old 01-06-2009, 10:23 AM   #6
It's the clear tube on the outside.
Dave and Yoshi [Ki6LBB]
http://www.adventureduo.com
Tread Lightly! Trainer
Pack it in Pack it Out>>>> http://www.trasharoo.com
Old 01-06-2009, 10:24 AM   #7
There's a clear tube on the rear end of the Atlas. There should be a black zip tie on the tube which indicates the proper fluid fill level. I dislike that method of indicating the proper level, as the zip tie can slide up and down.
Old 01-06-2009, 10:25 AM   #8
You beat me to the punch as I was typing!
Old 01-06-2009, 11:21 PM   #9
jlrray's Avatar
Wow. Thanks. I'll check that tomorrow.
Joe
