When i have to hit the brakes faster than i want too... like a light turns red at the wrong time or someone cuts me off, i get a little brake wobble in the front end. It goes away as we slow down. If i ease into the brakes it hardly ever does it.
Anyone else get this?
Running the Dynatac pro rock 60 first generation upfront.
Dave and Yoshi [Ki6LBB] https://www.adventureduo.com
2003 Baja Tan SMB EB50 V10 (SOLD in 2008)
2003 Baja Tan SMB EB DYO 7.3 Diesel
The most likely cause is that one of the front rotors is warped. On most vehicles you can have a brake shop turn/grind the rotors to true them. Unless you pads are new it probably would be good idea to replace them while you have everything apart.
John, Thanks for the response.. i thought maybe i was alone here on this topic. I will do a brake job on the truck ASAP. I will also turn the rotors or replace it they're really warped badly.
