Re: Brakes Question
Or a vacuum leak, or pinched hose to the vacuum booster.
Pull the vacuum hose off the vacuum reservoir. If you hear a big whoosh from air rushing in, you have vacuum and probably a bad booster. More likely, you will hear nothing because there is no vacuum. Then you have to find out why.
- Power to the Vacuum pump (diesel only)
- Vacuum leak
- Pinched hose
