Old 09-28-2010, 10:25 AM   #1
Changing Atlas TC fluid
I'm taking my SMB in for service next week, and am going to have the transfer case fluid changed. The work is being done at a Ford Dealer and they've work on The Van before, but if anyone has any tips that I can give them, I would appreciate it.
thanks..
Tom
2005 SMB RB 50 4X4 w/ a 6.0 PSD
flyfisher is offline   Reply With Quote
Old 10-02-2010, 12:21 AM   #2
cellularSTEVE's Avatar
Re: Changing Atlas TC fluid
You can remove the hose clamps on the site tube. Lower part to drain, upper to fill. If you do this I suggest replacing the tube and make sure to use the same length as existing. Be sure to mark the full level (should be 2 quarts-but double check) with a tie wrap/cable tie.
The other way is keep the tube in place and remove the brass parts that the tube goes into. You will need two wrenches.
In either method you will need a hand pump to fill the new fluid at the top where you removed the upper part of the tube. It will likely be too difficult to use a funnel.
I use the Torco fluid but you can use alternatives specified by Atlas.
Good luck,
steve
