Old 04-29-2009, 03:41 PM   #1
dual shock mounts? Remote reservoir shocks?
I need a little more dampening all around, but especially the rear (almost 8,000 pounds on my rear axle when loaded). I have seen dual shock mounts for all the American full size trucks. Anyone try using them on the E-series?
Or, would remote reservoir shocks work as well as dual shocks? Yes, I do have some quality mono-tube shocks now. But it's not enough when I'm bombing down rocky dirt roads at freeway speeds.
Old 05-03-2009, 10:38 PM   #2
deminimis's Avatar
Re: dual shock mounts? Remote reservoir shocks?
Rezies should do you fine. Bilstein 7100 are a good place to start.
Old 05-04-2009, 07:34 PM   #3
Is the setup in the photo above specifically for a Ford van setup or is it taken from another application.
onelegwarren is offline   Reply With Quote
Old 05-04-2009, 07:47 PM   #4
Yes. But it is not a stock Ford van. It has an SMB 4wd conversion with the front coil springs being replaced by leafs and the shock mounts (top and bottom) are moved and different style than stock. Other than that, the picture applies to all recent Ford vans.
Old 05-04-2009, 10:23 PM   #5
I'll stick to upgrading the rear for now. I think I'll do the stud-to eye conversion for the rear. Pretty straightforward, and go with the 7100 remote mount reservoir.
I'll probably go dual shocks up front. I don't want to lose travel doing the stud to eye conversion up front). It's easy to add a tab to run a 2nd stud mount shock. (That's what QuadVan does), and adding another horizontal stud to the axle shouldn't be too hard..
Old 05-05-2009, 06:55 AM   #6
My 5150 Bilsteins allowed me to unscreew the top eye and install a Bilstein Stud. I didn't loose as much length that way. I don't know about the 7100's but Bilsteins tech suport line is good and will give you the numbers for the stud kits.
Link to tech line numbers: http://www.bilstein.com/contact.php
Stumpalump is offline   Reply With Quote
