Old 05-08-2010, 07:48 PM   #1
Zeta's Avatar
Dynatrac axles
Does anyone know if SMB buys their Dynatrac axles off the rack, or if they are custom made for them.
Z
'06 RB50 SMB Diesel
http://www.tomsinclair.net
Old 05-08-2010, 08:25 PM   #2
Re: Dynatrac axles
It's the Dynatrack Pro Rock 60. There is nothing unique to SMB4x4.
http://www.google.com/search?q=pro+rock+60
and then
everything changed
Old 05-08-2010, 08:30 PM   #3
Zeta's Avatar
Re: Dynatrac axles
So it would bolt in?
'06 RB50 SMB Diesel
Old 05-08-2010, 08:46 PM   #4
Re: Dynatrac axles
To an SMB4x4, with the right spring perches, yes. But it's just a built, shaved 60. You could pull a junkyard 60 or 70 and be in about the same position... match the gears, put the spring perches on in the right place and you're good to go. What are you trying to do?
and then
everything changed
Old 05-09-2010, 09:10 AM   #5
Re: Dynatrac axles
I thought SMB had the center section moved a couple of inches to the driver's side. Clearly, it is further to that side than my F350 axle.
I went on the Dynatrac website, and while there are some 'Standard' ProRock axles (custom fit for Jeep CJ), they can be built with nearly any width, bolt pattern, brakes, spring/shock mounts you want.
So, I would have to say you can get a Dynatrac to fit a van, but a Dynatrac that someone has probably won't fit.
SOLD04 EB350 Custom Floorplan
6.0 PSD 4.10 Posi
Salem Kroger coil spring 4wd
2015 VW GTI
Leaving CA for WA
Old 05-09-2010, 07:10 PM   #6
UJOINT's Avatar
Re: Dynatrac axles
Exactly. There are a few bolt in replacement axles, but all Dynatrac axles are built custom. The SMB front axle is specific to SMB, set up to their specs.
Chris Steuber
02 E350 7.3 (V4)
05 E350 V10 (V7)
17 Focus RS,90 SHO,49 Willy CJ2A
ujointoffroad.com
