Originally Posted by haywoodphotomaccom
Anzac, so why not run around 35 PSI on all tires if they are all roughly taking the same load? 1910 lbs each time at 35-40PSI. 7600 lbs carry capacity and van is 7000ish.
You could ask the same question with stock tires and stock pressures, and the answer would be, don't drive around with your tires under inflated. This exercise is not about finding the right pressure for a given loaded weight, it is about matching the OEM specified maximum capacity.
