Old 08-18-2012, 12:34 PM   #1
E450 4X4 CONVERSION
HELLO ALL,I'M NEW TO THE FORUM AND JOINED TO GET SOME ADVICE AND SUPPORT ON AN UPCOMING PROJECT I'M PLANNING.I HAVE A 97 E450 FORMER AMBULANCE THAT I PLAN ON CONVERTING TO A 4X4 .THE TRUCK IS IN GREAT SHAPE WITH ONLY 40K MILES AND HAS A 7.3 POWERSTROKE, E4OD TRANS AND DANA 80 REAR DIFF.,NOT TO MENTION AN ALUMINUM BOX ON THE BACK THATS INSULATED,HEATED AND AIR CONDITIONED.I'VE BEEN CONTEMPLATING THIS PROJECT FOR A WHILE AND NOW THAT I JUST CAME ACROSS THE PERFECT DONOR VEHICLE THERE'S NO REASON TO CONTEMPLATE ANYMORE.I JUST PICKED UPA 95 QUIGLEY E350 4X4 VAN WITH A 7.3 POWERSTROKE,E4OD ,BW 1356 TRANSFER CASE & DANA 60 FRONT DIFF.MOST OF THE CONVERSION WILL BE STRAIGHT FORWARD WITH A FEW EXCEPTIONS SUCH AS THE E BRAKE OFF THE REAR OF THE 4X2 TRANS WILL BE LOST WHEN THE TRANSFER CASE IS INSTALLED AND I'LL HAVE TO DO A GEAR SWAP IN THE FRONT DIFF. TO MATCH MY REAR BUT OTHER THAN THAT I DON'T SEEE ANY ISSUE.HAS ANYBODY HERE DONE DONE A SIMILAR CONVERSION ON A E450 AND IF SO WHAT PROBLEMS IF ANY HAVE YOU ENCOUNTERED ?ANY INPUT WOULD BE APPRECIATED.
fourbyamb is offline   Reply With Quote
Old 08-18-2012, 02:52 PM   #2
Gnarvan's Avatar
Re: E450 4X4 CONVERSION
I'm not sure about your application but you might have a space conflict with the transfer case and the stock fuel tank.
John
Gnarvan 1992 E350 Clubwagon
2003 BMW R1150GS-Adventure
2013 BMW R1200GS-Adventure
Old 08-18-2012, 03:06 PM   #3
GOT THAT ONE COVERED ,LUCKILY I ALREADY HAVE A 55 GALLON TANK MOUNTED BEHIND THE REAR AXLE,PLUS IF I WANTED TO REALLY EXTEND MY RANGE THE DONOR QUIGLEY HAS A SHORTENED TANK ON DRIVERS FRAME RAIL THAT I COULD ADD TOO.
Old 08-19-2012, 06:31 AM   #4
Stop yelling. (CAPS)
Great base for a project! Good Luck to you.Check with Chris at Ujoint. He will have answers to most of your conversion questions.
Desert Solitaire
2003 7.3L EB 4x4
Timberline 4x4 conversion
