Old 01-31-2017, 04:39 PM   #1
Wanderlust Bus's Avatar
Fender rubbing problems
My front tires are rubbing the fender when I turn with only a little bit of suspension compression. I'm planning on getting some fender flares, and I want to eliminate the rubbing so I don't rip the flares off.
Right now, I think the wheels have a -12 offset. I'm guessing that a 0 or +6 offset will help eliminate the rubbing.
Or, would it be easier to just get out the sawzall and trim the fenders? (I really don't want to do this)
Wanderlust Bus is offline   Reply With Quote
Old 01-31-2017, 05:13 PM   #2
rallypanam's Avatar
http://www.sportsmobileforum.com/for...ers-18043.html
Old 01-31-2017, 05:16 PM   #3
Originally Posted by rallypanam View Post
You make it look easy.
My next door neighbor works at a body shop. Maybe I'll just buy him a case of beer and bribe him.
Old 01-31-2017, 07:24 PM   #4
SheepShagger's Avatar
Here is another way.
This weekends project, 35" on a Quigley. (DIY Fender trimming) - Expedition Portal)
This is probably more metal work than previous post, but doesn't require welding and filling if your going to slap fender flares. I didn't have welder handy when I did mine, so it dictated this method. I do have welder now so ill weld and fill mine back up when I get time.
Old 01-31-2017, 09:04 PM   #5
I looked at that thread earlier. I think that's what I'll do. You make it look simple.
Sent from my SM-G930P using Tapatalk
Old 05-26-2017, 05:57 PM   #6
i took 5 min and trimmed my fender with a sawzall. but i'm gangster
jblaze5779 is offline   Reply With Quote
Old 06-07-2017, 01:16 AM   #7
Fiberglass fenders
We are making fiberglass fender for the new body style. i will post more pics on the van, until then here is a peak. The wheel opening is larger giving you additional clearance in the rear section.
WeldTecDesigns is offline   Reply With Quote
