Old 10-23-2019, 11:40 AM   #1
Annie O's Avatar
Fox-ated on shocks! Third set in 3 years
Hello All! Long time no post... trying to leave town for camping but first: another leaky shock. This would be my 3rd Fox in as many years! Sadly I’ve not been off road this past year and too many highway miles, plus I relocated.
2016 bought Hellbetty had RIP kit installed
2018 passenger side shock leaked, replaced pair
2019 passenger side shock leaking, need to replace pair I guess and keep the extra set, have re-valved and keep for spare �� (Mad I just sold my old pair a month ago). Of course they’re off warranty.
Anyone else go through that many Foxes? They are Agile tuned.... can send in for re-valving but HellBetty is my only vehicle now. I don’t mind the Agile upcharge except I’m having to replace these too often.
Of course I’ve had other steering/suspension work too. (Redhead, dual steering stabilizer, new brakes/rotors/calipers. Maybe I need to drive highways less and camp more.... anyone have alternate idea? TIA!
P. S. Yes I know there’s rust I live in the Midwest, after all
Annie O is offline   Reply With Quote
Old 10-23-2019, 12:14 PM   #2
Makes me wonder if there isn't a shock (mount) misalignment issue leading to the leaks.
Old 10-23-2019, 12:33 PM   #3
Originally Posted by BroncoHauler View Post
Makes me wonder if there isn't a shock (mount) misalignment issue leading to the leaks.Herb
That was my first thought too. You might also consider adding shock boots to protect the shaft that is subject to pitting from being assaulted by gravel, rocks, road salt etc. One little pit will tear up the seal and cause a leak. I've had my rear set for several years with no sign of leakage, but I've run boots from the beginning. Good luck, nice to see you around again. Care to join us for a trip to Death valley, the Mojave trail, the hammers race, and then Baja? Beginning in Feb.................
Old 10-23-2019, 01:46 PM   #4
Houstonredrider's Avatar
I had one shock leaking after few weeks. I got them through U-Joint and Chris got me the replacement pretty quick. Two years later no issues.
https://www.expeditionportal.com/for....167666/page-7
2010 E350 4x4 MG Coil conversion
Houstonredrider is offline   Reply With Quote
Old 10-23-2019, 04:58 PM   #5
That was my thought. Mounting them shaft-down without boots puts the shafts in the line-of-fire for whatever is being thrown of the front tires.
Old 10-23-2019, 05:49 PM   #6
shenrie's Avatar
i asked ramsey about boots when I ordered the rip kit when he first started offering them. he said they weren’t needed. I asked john about boots when I bent a shaft and had all mine revalved a few years ago. he said typically it wasn’t necessary, but with the harsh winter conditions I subject mine to that it might not be a bad idea.
personally, I don’t really see a downside to shock boots, but I’m sure someone will respond and remind me of a few reasons
Old 10-23-2019, 09:24 PM   #7
He told me the same thing, but I already had them and saw no reason to leave them off, what could it hurt? So far, so good........
Old 10-24-2019, 10:56 PM   #8
REF
REF's Avatar
Send a message via MSN to REF
I think there’s a school of thought out there that if you’re running boots, you may not see a leak if one were to occur. I am currently running them only on the rears, I may add them to the fronts when I replace/revalve.
Old 10-25-2019, 05:38 AM   #9
shenrie's Avatar
^^^ yep, now that you say it, I believe that’s exactly what both of them had mentioned. thanks for posting that up ref
Old 10-25-2019, 06:04 AM   #10
There's also a risk of trapping sand or mud stuck INSIDE the boot. But I think that risk is lower than the guaranteed rock pelting they take, especially when they have to be installed shaft-down.
Vanzilla
Glenn P.
Esme
Amy V
