Old 05-12-2017, 06:59 AM   #1
Front sway bar - bolt into frame
I searched but couldn't find an answer so I thought I'd ask.....
The front sway bar bushings (the ones under the radiator - NOT on the axle) are held in place by a bolted clamp. It seems the bolts go into threads or a captive nut in the front frame horn.....Is this accurate? One of those threaded parts is stripped....I have an arb bumper on the front and am wondering if I remove the bumper...
Is the end of the frame horn open to allow access for putting a nut on the bolt? Bolt removed in photo - the bolt spins freely in this hole (ie the threads in the frame horn are stripped....)
stayalert is offline   Reply With Quote
Old 05-12-2017, 07:03 AM   #2
Just tap it the next size up, then spray some good anti corrosion spray/grease/paint whatever over the top after its put back together.
Old 05-12-2017, 07:04 AM   #3
Yes, there is access to put a nut on the bolt.
Old 05-12-2017, 07:10 AM   #4
Thanks guys! I've been considering both options....
