Old 09-18-2013, 11:01 AM   #1
Ridge's Avatar
GM 14 Bolt rear end swap
I scored on a 14 Bolt from a military surplus lot for $450. It's in great shape with 4:56 gears and a Detroit locker. I bought the disc brake conversion kit that uses GM truck front rotors.
I needed to re-gear anyway (35" tires), and a strong locker isn't going to hurt. Plus, that axle is a full floater so if I do break an axle shaft I can still roll down the road without losing a wheel. This axle is pretty heavy duty.
I'll take some pics...hopefully it fits! The leaf springs are really wide on the van and it might interfere with the brakes. I should know something by the end of the day.
Chris
Ridge is offline   Reply With Quote
Old 09-18-2013, 11:44 AM   #2
Re: GM 14 Bolt rear end swap
Does it have the off-set differential? THe vans do. I though most versions of the 14-bolt have a centered differential?
Reunel rear bumper
Old 09-18-2013, 11:53 PM   #3
Ridge's Avatar
This 14 bolt is off-set to the passenger side.
Old 09-23-2013, 12:58 PM   #4
UJOINT's Avatar
No rear axle VSS on that 14 bolt.
Chris Steuber
02 E350 7.3 (V4)
00 E250 5.4 (V6)
05 E350 V10 (V7)
99 E36 M3
http://www.ujointoffroad.com
Old 09-23-2013, 04:27 PM   #5
BajaSportsmobile's Avatar
It is easy to add, we do them on swaps quite often.
AgileOffRoad.com
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
