Old 10-02-2010, 07:11 PM   #1
ScotFree's Avatar
Ground Clearance: How much is Enough?
Hello all,
Newbie has searched here but can't find anything on point so I'll start this in hopes of some experienced opinion.
Currently comparing 3 4x4 Conversion shops for my 08 E350 EB. All will lift the van 4" ABOVE the axle centerline, plus 17" replacement wheels/tires. That raises the center of gravity 4" to a vehicle that some safety groups already consider dangerously top-heavy.
Tire height is the only component that raises Clearace, right? By Clearance, I mean distance from ground to bottom of Diff on the level. Factory is 8.2." with 29" tires/wheels. 33" tires will increase Clearance to about 10". So, if folks with experience could assure me that 9" Clearance is enough, then I could go with 31" tires and keep the C of G and entry/exit height an inch lower. Plus the 33s will require the front fenders to be cut out + flares, which I would rather not do.
My usage:
60%-Highway with occaisional snow.
30%-maintained County Roads with some pot-holes & miles of Washboard.
10%-5mi jogs to secluded campsites on Forest Service/BLM trails with some steep hills often littered with chunk rocks the size of 1-2 gal. jugs. Most of these can be negotiated, but some lie in ambush in vegetation between the tracks. (Sneaky Rocks!)
Also, I have not seen mention of a Skid Plate for the Diff? Any input will be appreciated.
'08 E350 SD EB Cargo 6.0
Bought New 5/2010
Quad Van 4x4
Rudimentary DIY Camper
ScotFree is offline   Reply With Quote
Old 10-02-2010, 09:24 PM   #2
yvrr's Avatar
Re: Ground Clearance: How much is Enough?
The "trick" to negotiating off-road rocks is not to worry about clearance under the differential but clearance under the nerf bars, i.e., directly in line with the front tires. When you encounter rocks, drive directly for them and get your front tire onto them. That way, you are not trying to clear them with the differentials but need only enough body clearance in line with the front doors. After the front tire drops down, do the same thing with the rear tire. No problem....
If the road is too narrow to drive over the rock with your tires, have a spotter position you so that the rock is between the tire and the differential (closer to the tire where there is more ground clearance).
Likewise for rock steps...have the spotter position you so that both front (and then rear) tires drop off the steps at the same time...the differentials will clear without a problem.
The only time I thought we had a problem was coming off some steps that were on an angle. That meant that it was impossible for both tires to come down at the same time. From my angle in the driver's seat, I was sure that the steps were too high. But my wife was spotting me (which would have made her responsible if we got hung up <g>) and kept motioning me to come ahead slowly. She gave me a signal that the first front tire was about to drop down about 8" and when it dropped down, gave me a signal that the differential still have 3-4" of clearance! No sweat! And our van was only 2-1/2 weeks old at the time! That trail (Eye of the Whale) was rated as a 6 (out of 10) in Massey/Wilson's Utah book.
Jack
'01 Ford EB50p Quigley 4WD
Old 10-03-2010, 03:48 PM   #3
geoffff's Avatar
I've never had any clearance problems with my Sportsmobile 4x4, even with the "smaller" LT285/75R16 tires, in the kind of travels I like to do -- mostly Massey/Wilson adventuring like yvrr suggests. It's extremely rare that I contact rocks with the bottom of my van (though I have hit my nerf bars a few times fooling around). I haven't taken the van up the Eye of the Whale trail yet, but I once did so with my Jeep Grand Cherokee and that has less than 9" clearance. For the kind of use you describe -- especially if you're thinking about wheel placement -- you should have no trouble with the a van lifted the minimal 4".
-- Geoff
2004 Ford, SMB 4x4, RB-50
Old 10-03-2010, 06:24 PM   #4
Two thoughts to consider:
1. Don't know about all conversions, but SMB and Quadvan conversions both increase axle width. This helps mitigate increased hight of the CG. Mine is an SMB and is significantly more stable post conversion.
2. In my not-so-humble opinion, diff skids are not the way to go (this from a guy with nearly everything protected underneath both SMB and Jeep). Heavy duty covers are the way to go. I had multiple problems with leaking diffs on my Jeep. Switched to Dynatrac covers and haven't had a leak since. So, I added the Dynatrac cover to the rear diff of my van as well.
Hope that helps.
Current: 2014 15 Passenger V8
Former: 2009 SMB 4x4 6.0
Old 10-03-2010, 07:15 PM   #5
ScotFree's Avatar
jessenej, I hadn't heard of a Diff Cover, good tip, I'll look into it.
And Geoff's comment about his Jeep is a help, because he gave his Diff Height. It seems to me we have to specify Diff Clearance as the standard of reference, then we can compare experiece regardless of whose build we have or how much lift, or what size tires. Thanks, hope to get some more input, but I am leaning toward the 31" tires and 9" Diff Clearance. I just hope they don't look like little donuts in my 4" body lift.
Bought New 5/2010
Quad Van 4x4
Old 10-03-2010, 07:17 PM   #6
ScotFree's Avatar
P.S.
If anyone has a picture of 31" tires in 4" lift, I would love to see it. Thanks again.
Bought New 5/2010
Quad Van 4x4
Old 10-04-2010, 08:51 AM   #7
I don't rock bash that much, and never in the van. I don't see a need for insane diff cover protection, because if a rock is too big I just turn around and go another way. If you're going to build for things the van will never see, you might as well look into Rockwells...
Old 10-04-2010, 11:24 AM   #8
geoffff's Avatar
Well, my 285/75R16 tires are just about 33", and they even look a bit small on my van, I'd say. But they seem to work for me.
Compare to twolost's van with 35"s:
-- Geoff
Old 10-04-2010, 01:41 PM   #9
I have a standard SMB conversion and take it in some places I probably shouldn't. I'm running 285's on 16" rims. I get zero rubbing on trails so I'll probably stick to that size. I do like the looks of the taller tires though but haven't had problems with how my van is set up. Plenty of pics in my album.
I agree with the previous posts and when it gets too rough, go back. Tire placement is important but if you have to there are ways around, such as stacking rocks to get you out of a situation. BTW being able to pull the disconnects on the sway bar helps such as in this picture.
Old 10-04-2010, 10:12 PM   #10
UJOINT's Avatar
Don't just consider ground clearance to the diffs. Quite a few conversions use radius arms that hang down low and can easily be damaged.
I also agree with the above posts. If you need more clearance, maybe you shouldn't be there! Of course I said this before I caved in my rocker panel on a rock.....
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
