07-21-2018, 03:08 PM
#31
I would be very surprised if the Hellwigs were the only factor in the frame cracks. Mine haven't cracked (of course, I'm only a sample size of 1... ), and I have torn the bolts out of the front driver side, and my van has been very airborne as well, not to mention I'm normally very heavily loaded.
The E-series frame is normally very ductile, so I'm surprised to see you had any cracking at all. Is it possible it was heat damaged during install (like a dull drill bit was used?). Or maybe you got a fluke frame that was heat damaged during manufacturing (like it got left in the paint booth on a friday PM, over the weekend)...
07-22-2018, 11:17 AM
#32
I've had hellwigs on an E350 2X, and removed the rear due to tripoding. The rear was great on the road, but off camber with the front it was a bit much for my weight. Have not been totally airborne, but occasionally find some baja dips too late. No sign of issues, but the rail loads would come from off camber shock, not straight on rolling. Front hellwig works great. Front is the 1 1/8 version, and they do offer a stiffer 1 3/8 front one.
Also don't quite understand the swaybar mounting in the OP. Mine has a frame doubler running fore and aft wrapping the inner frame half with no adjacent (welds), and the picture shows a bracket spanning the frame just aft of the mount...Difference in the 4X4 mod? or I find it hard to believe there is a 2012/2006 frame difference. This may be a 4X4 only discussion?
Pac NW and warmer places
2006 E350 EB Elect Top 2WD
07-22-2018, 03:59 PM
#33
Ok you guys made go out and look at my sway bar to see if I have anything happening. I just have the front and it’s all good on a 18 year old van. I did have one bushing that popped out while coming down from Funnel lake last week and is the new clunk I picked up. I cant disconnect mine and it’s been pretty good both on and off road and I did notice the handling difference with it now loose.
07-23-2018, 12:22 AM
#34
Nemisisnight- Boulder off Road fabricated the new upper mounting bracket and installed the larger front sway bar with end links, eliminating where the original sway bars usually end in the often wallowed out bushings. The end links were then replaced with disconnects, and yes, this is on a Quigley. I can send you some more pics by PM if you want.
Sorry for the derailment......
07-23-2018, 10:35 PM
#35
Send pics please
07-24-2018, 12:20 AM
#36
I had posted this up in the “what did you do....” thread a bit ago, but it’s huge. Here’s a few photos of it- there’s a pin that you pull to swing the disconnects up to the upper pin to get them out of the way
07-24-2018, 10:03 PM
#37
Thank you now I have ideas
07-31-2018, 06:44 PM
#38
I agree about detachable sways. I though SMB had such mounts on their 4WD builds; I recall that cuz I wanted to get some but no dice. In fact, I don't think I ever saw ANY detachable quick release type links that could handle the weight of a SMB. On my van one can just unbolt them, but it's kind of a pain to hang the thing out of the way.
And I would never ever drive the road without a beefy sway bar. While it's not great to use one offroad as previously noted, the opposite is true ON the road, and a rollover there is more likely to kill you, no?
Still, pretty alarming damage. That would seem to total the van. Yikes. And is it just the photo, or does the whole frame rail seem bent?
08-04-2018, 08:57 PM
#39
With just one bushing out of place I noticed a big difference in handling and a roll to the van.
