Old 07-19-2013, 01:04 PM   #1
Dango's Avatar
Hiccups
My '94, 5.8, 351 is missing at idle and in drive- particularly at 25-30 and then again at 60mph. It was running fine until I parked it in the sand at Pismo Beach. Did a little 4-wheeling but nothing major.
It's been in the shop for 4-days now and they cannot find the problem. Timing was adjusted, new plugs, plug wires, gas and air filters, etc. They stuck a new fuel pump on and then took it off as that was not the cause. They've had it on the diagnosis machine and eliminated all of the codes that have popped up. It's got a fresh tank with 91 octane. Today they're going to do a compression test on the cylinders and valves but I highly doubt that could be the problem.
Are we missing something here? Looking for any suggestions...
Thanks.
Dango is offline   Reply With Quote
Old 07-19-2013, 01:56 PM   #2
Re: Hiccups
My gut says ignition module or ignition coil. Any vacuum leaks at the intake manifold or throttle body?
Build in planning stages - SMB-West or UJOR 4x4, V-10, Pueblo Gold, lots of other stuff...
lndshark is offline   Reply With Quote
Old 07-19-2013, 02:23 PM   #3
Dango's Avatar
Re: Hiccups
No vacuum leaks and he's checked the coil. Don't know about the ignition module. I'll call him right now and ask.
Thank you.
Old 07-19-2013, 04:24 PM   #4
Dango's Avatar
Re: Hiccups
Yep. Ignition module, throttle body and mass air flow sensor have all been checked as well. I'm still looking for an answer as I have to drive it 2200 miles by next weekend (my mechanic is closed this Sat and Sun).
Old 07-19-2013, 11:14 PM   #5
Re: Hiccups
Clean the crankshaft position sensor. Probably has crud on it. Check the wiring while your at it. But speed sensors faulting at certain frequencies is usually metal contamination.
Old 07-20-2013, 12:00 AM   #6
Dango's Avatar
Re: Hiccups
Thanks for the advice. We didn't think of that one (crankshaft sensor)...nor do I have any idea what it is! I'll let my guy know tomorrow.
Old 07-22-2013, 03:29 PM   #7
Dango's Avatar
Re: Hiccups
Wow. It's now the 7th day at the mechanic's (2nd one) and still no diagnosis as to why it's missing. Ford, you're killing me.
Old 07-22-2013, 11:37 PM   #8
BajaSportsmobile's Avatar
Re: Hiccups
Worn out distributor drive gear.
AgileOffRoad.com
Old 07-23-2013, 01:34 AM   #9
Dango's Avatar
Re: Hiccups
I'll pass it on. I have to be 2200 miles away by next weekend for a wedding. I need this dilemma resolved. And quick. Thanks.
Old 07-23-2013, 02:44 PM   #10
Dango's Avatar
Re: Hiccups
ECM. $1500 later for a $200 part. On the road again...
