Anyone know where to find replacement hub covers? I'm replacing the Discount Tire D range T/As for the correct E load range, and the hub covers are too rusty to rescue. Thanks.
They will be available from most after market Custom Wheel and Tire supplier's . If possible try to get them in Stainless Steel if your budget permits . If not then spray the inside of your new Hub's with a good Epoxy or weather resistant spray paint (Rustoleum) works well , do this a couple of day's prior to the reinstallation to allow for drying of the paint/epoxy and you will probably never need to replace them again . This is especially good if you encounter alkaline rich soils so prevalent in our Western States .
Greggde
