Originally Posted by Pete
My axle looks the same. Is there no drain plug on this thing? I couldn't find one, so it seems the only way to drain the thing is to pull the diff cover off?
Correct. You can suck it out with a suction/tube through the fill hole but you won't get all the gunk down the bottom.
Pulling the cover is worth it, you just need to make sure you clean up the gasket face on both cover and housing. The Mag Hytec covers use an O-ring (like their tranny pans) which makes life even easier (no need for RTV). It looks to me like the Mag Hytec cover doubles the fluid capacity (6 pints->6 quarts).
I am still checking on what LE oil they have that is 80w90. Mag Hytec recommended LE 607, which is SAE 90 but is now obsolete and Mag Hytec says is replaced by something that is SAE 110. I noticed LE have 703 which is 80w90. I'm pretty happy with how the LE ATF worked in my 99 transmission, so would like to see if they have something suitable for the diff. Found this article on the obsolete LE-607 which you may find interesting (page 1):
www.le-inc.com/DownloadResource?resourceID=61
