Installed New Steering Stabilizer...Can’t Turn Right
I’m installing my Agile RIP kit, working on it in the 20 minute increments I get. I did the rear shocks and steering stabilizer today. (2004 E350 Quigley)
My nephews came over for a ride in the “Big Blue Bus” and so trying to be the cool uncle I took them out for a ride and made it half a block before I realized I can’t turn more than a few degrees right.
I imagine it’s a simple fix but now it’s dark and snowing and I just trying to have a game plan to fix this quickly.
I did not make sure to have the wheels in any certain position or anything else really, I just took off the original and bolted in the Fox from Agile.
-Maybe I over torqued something and it’s binding?
-Maybe I need to move the position of the bracket on the tie rod?
So, basically I just need to move the track bar bracket so the stabilizer is extended 50% and the wheels are straight? (Leaving half of the travel for left and half for right).
Well I just figured out part of the problem, now that I had a chance to go look in daylight.
The regular Quigley set-up has the body of the stabilizer bolted to the frame and the extended end of the stabilizer bolted to the track bar.
I switched this becuase the body of the Fox stabilizer is so much larger than the Quigley stabilizer that the frame side mount can’t accommodate the fat Fox stabilizer.
You can see in the picture where the body of the shock hit the frame mount, slightly gouging each surface. The solution, I guess, is to make a small spacer, about 3/4”, that moves the body of the Fox stabilizer away from the frame mount.
