04-24-2015, 10:22 PM
Re: Irritating rattle from 4x4 shift levers
Interesting as I have a QuadVan conversion with the Ford TCase with the same noise....
04-24-2015, 10:48 PM
This was my high tech fix. It is not pretty but it works as a dampner and much better than that irritating noise on long trips.
Steve
2006 EB Transformer SMB 4x4 Diesel PH F/R Aluminess SOLD February 2015
2009 EB E350 V10 Quigley - Non-SMB
2005 4x4 Excursion 6.0 Diesel EB Magnaflow Superchip - Bulletproofed
04-24-2015, 11:22 PM
Originally Posted by GrumpyBadger
I'll probably give Peter DT at SMBW a jingle and see what his experience has been. Obviously mine isn't the first manifestation of this gremlin.
If you talk with Peter, you can add our van to your list of sufferees.
Don
-Don-
Life and baseball both sometimes are not fair, but it is how you play the hops that counts. —Scott Miller, NYT Sports
06-04-2015, 06:00 PM
Ours does the same, and the way we fixed it was to get one of those colorful pool noodles (for less than a buck), cut it to where it was just 1/4" longer than the exposed shift lever arm, then wrapped it around the exposed part of the arm - hard to describe. That took care of it. I'll take a picture tonight.
06-05-2015, 05:31 AM
G'day Grumpy,
Reading all these posts about Atlas Transfer case issues is making me feel a whole lot better about my Advanced 4WD
Conversion. I am still worried till I get there in just 2.5 weeks time, to know what they have done, with what and how.
Grumpy, yours is a beautiful machine, just a few teething problems.
I've had two Jensen Healy's and two Lotus Esprits, and with low volume, handmade vehicles, you get issues.
I had an Australian made 5 ton 4x4 truck called an OKA, that had 4.5 litre Perkins engine, with a half ton bullbar, you had to work the gears, great chassis, 9 seats, width was over standard track.
Amazing vehicle, poor build quality, engine too small, 6-7 litre diesel would have been better.
Good Luck, you will fix it, Cheers.
2008 Yellow Ford E350 6.0 diesel eb50 4x4, Front E Locker, Asheville Eng Rebuil 20th @ 261miles, ARP Studds, 200amp Alternator, Performance Aluminium Radiator, OnBoardAir, RoadmasterActiveSuspension, Front & Rear Aluminess with Spare Tire Carrier, Aluminess Roof Rack, Titan Aft 30gallon Fuel Tank.
06-05-2015, 09:05 AM
Doug: Don't stress too much, your van looks great! I crawled all over the thing at SMB West a couple of weeks ago.......it's one of their display vans at the moment.
06-05-2015, 12:19 PM
Cheers Boywonder!
06-08-2015, 11:00 PM
Mine has done this since new. Primarily on the highway when I'm doing 50 mph or above. Drives me crazy. My van only has about 7K miles on it. I've had it back up to Fresno for a fix but it started again on the drive home to San Diego. I'll have it up there again in the Fall for another look.
Mine seems to be only the rear drive lever. If I pul it back toward the rear slightly when driving the noise stops.
06-15-2015, 07:11 PM
Ours has done the same thing since we got it.
I fixed it pretty much in the first couple of weeks.
This is what I used to fix it. http://www.cabelas.com/product/Sims-Lim ... id=crrdtfd
Essentially its a rifle barrel de-resonator. Designed to take the harmonics out of a rifle barrel when shot.
It works brilliantly and not very expensive. Take the knob off the shaft of the offending shifter, lubricate slightly, and then slide the de-resonator onto the shaft. It should be wicked tight and almost hard to get pushed down the shaft far enough.
Problem solved.
06-21-2015, 03:46 PM
#20
Ok, took me a little longer than promised to upload the photo
Here is our silly solution, as mentioned earlier in this thread:
