Thanks MG.
Originally Posted by mgmetalworks
What size tire do you plan on running?
I'll probably be running about a 33" tire. I'm going for a look that is more on the stealth side.
Fortunately the coil springs are fairly cheap and you can test out different pairs pretty easily.
Yep, and I don't mind spending a bit to do that. I'm collecting parts and wanted to make sure that the Carli bar would still work for various lift heights since it is more expensive.
