Old 03-18-2019, 11:42 AM   #121
I guess 17x9 -14mm is 4.45” backspacing so they should work fine since 4.5”-5.5” backspacing is recommended. Thanks for your help I just didn’t want to order wheels that wouldn’t work.
jacobthrock is offline   Reply With Quote
Old 03-27-2019, 05:58 AM   #122
schluchtenflitzer's Avatar
@MG Metal works:
First of all i have to say that the work and all the information MG Metal works gives here is amazing!
I realy appreciate this and i love how extremly professional the work is done!
I am wondering if and how the crossmember is reinforced after cutting. I never saw a picture of this from you. I would like to see this
Thanks
Didi
www.Dieda-unterwegs.net
schluchtenflitzer is offline   Reply With Quote
Old 03-27-2019, 11:11 AM   #123
Jsweezy's Avatar
This is how it was done with my van. A little cut here, weld there.
Old 03-28-2019, 02:54 AM   #124
Thanks but i mean the crossmember under the oilpan. This normaly has to be cut because of the front axle.
Old 03-28-2019, 07:42 AM   #125
Jsweezy's Avatar
Oh gotcha. It's not that difficult really, I just kind of followed the brake line but I know MG has some sort of template. Just make sure all your corners are rounded when you cut so they arent weak spots later on.
Old 03-28-2019, 09:23 AM   #126
Thanks for the kind words schluchtenflitzer!
We do have a trim template that we send out. It's a PDF file that you can print and cut out.
Old 03-30-2019, 09:30 AM   #127
Thanks @ Jsweezy and mgmetalworks
so no reinforcement is necessary?
Old 04-04-2019, 05:21 PM   #128
Crossmember cut went much easier than I expected. Initial cut using 4.5" 60 grit cut-off wheel (Harbor Freight), followed by grinding wheel to knock off and shape a little, finished with sanding wheel. Light sand and paint.
I had limited access for the initial cut from the front, so transferred line to rear of plate being cut and cut from rear. Disadvantage of this was a face fill of sparks.
See more at https://www.facebook.com/4x4-Expedit...1379148121143/
wild-kiwi is offline   Reply With Quote
Old 04-04-2019, 05:28 PM   #129
Sway-bar instal.
Sway-bar final assembly. Moved the OEM E350 sway bar chassis attachment point 2" forward for sway-bar ends to clear coil springs and allow for full travel movement around installed track bar mount.
Extended OEM F350 sway-bar linkages (Ford part # PSA55939) from 4.25" to 7.5" to raise linkage / sway-bar attachment point allowing for an optimal vertical linkage and horizontal sway-bar configeration.
Van drove ok without the sway-bar, but the installation is very noticeable with significantly less to no body roll while cornering. In general van now drives better than pre-lift.
20190403_154532.jpg   20190404_164221.jpg   20190404_165153.jpg   20190404_165647.jpg   20190404_165700.jpg
Old 04-20-2019, 06:52 AM   #130
Originally Posted by wild-kiwi View Post
Fox 985-24-061
are these the shocks needed if you're switching to the sterling 10.5 rear? thank you
