Old 06-04-2012, 07:01 PM   #1
ridintall's Avatar
Need new wheel studs - Correct Track spacers
Does anyone know the size and/or a source for replacement wheel studs for Correct Track wheel spacers? I bought them direct from Correct Track in 2004 which has since gone out of business. Over the years the threads have worn on several of the studs so I'd like to replace them all. I'm due for rear brakes so it's a good time to replace the studs since the spacers need to come off anyway.
Thanks much
2004 E350 6.0 Diesel
SMB RB50
ridintall is offline   Reply With Quote
Old 06-04-2012, 08:50 PM   #2
ANZAC's Avatar
Re: Need new wheel studs - Correct Track spacers
PM UJOINT on this forum.
Sportsmobile-less.
Old 06-04-2012, 09:03 PM   #3
Take one in to NAPA. Or a Les Schwab's. I strongly suspect there is nothing unique about them.
Old 06-04-2012, 09:30 PM   #4
BIGVANS's Avatar
Thanks much
SMB RB50
This is them ...... Still in Grants Pass, OR
http://www.hendersonslineup.com/
They make the aluminum ones that they use on RV’s. U-Joint has steel ones but the studs may be the same.
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 06-04-2012, 10:11 PM   #5
If you cant find any studs for them, I have a pair of 2" spacers for sale for ($100.00)
cowboy4x4 is offline   Reply With Quote
Old 06-07-2012, 06:03 PM   #6
Or, you can knock (press) out a stud and take it to a good auto parts house and they can match it.
Old 06-08-2012, 05:20 PM   #7
ridintall's Avatar
Thanks everyone for the input. I contacted SMB West and Hendersons. SMB didn't know the size and Hendersons doesn't sell the studs separate from their wheel spacers. My plan is to pull one when I'm ready to do my brakes and hit an auto parts store. I also saw that ARP makes wheel studs so I may contact them as well. I'll post an update once I have more info.
Bamulance
charlie mike
Biggie
Berta
