Old 02-12-2017, 10:30 AM   #11
Wanderlust Bus's Avatar
Originally Posted by UJOINT View Post
We use some Gates 90 degree hoses and straight adapters to shorten it all up.
That's exactly how ours is right now and it still interferes.
Sent from my SM-G930P using Tapatalk
Wanderlust Bus is offline   Reply With Quote
Old 02-12-2017, 11:22 AM   #12
JackTuppVan's Avatar
I was also going to suggest 90 degree hoses
but if that hasn't worked for you
You might try a oil heat exchanger intended for the Ford truck.
Ford F150 F250 F350 5.4 6.8 heat exchanger F8UZ6A642HA
(the oil lines are located on the side of the heat exchanger)
Oil Cooler Ford F150 F250 F350 Super Duty 5.4 6.8 heat exchanger F8UZ6A642HA | eBay
dimensions are in the PDF
www.modine.com/download/a3086b1923ae41614a78e54550d8d257/44-156.pdf
2007 E250 Super Duty cargo
1988 Toyota Van 4x4 5-spd
Old 02-12-2017, 07:01 PM   #13
dig255's Avatar
My SMB built van has exact same problem. I was just going to tierap some sort of metal shield over the hoseses.
dig255 is offline   Reply With Quote
Old 02-13-2017, 02:54 PM   #14
All the parts are ordered and are on the way, but it could take me a couple weeks to actually get it finished. I'll take a bunch of pics and get a nice easy way to take care of this problem.
Old 02-13-2017, 06:58 PM   #15
UJOINT's Avatar
Maybe the filters are a different size but our lines are above it, protected by the rear of the engine x-member.
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
Old 02-27-2017, 11:00 AM   #16
I think I've got all the parts on the way. I've tried a few different solutions laid out on the garage floor and this is the one I've settled on. I think this will work assuming the oil filter has a backflow/check valve built in (Wix 51515xp). It's a super simplified drawing, but it gets the point across.
Old 02-27-2017, 03:05 PM   #17
Pntyrmvr's Avatar
I dislike hose clamps on line that may see the high side of 75 psi. That must be counter balanced with hard lines getting crushed by impact from below. In the field a crushed metal line is junk. The hoses can be re worked, or even stolen from a heater core circuit to get the leaking part bypassed.
I suggest the highest quality rubber line dedicated to oil cooling and the style of clamps that completely encircle the hose with a smooth, snag free clamping face.
Old 02-27-2017, 03:20 PM   #18
Glider's Avatar
If you are setting up a bypass system anyway, have you considered doing an Amsoil dual filter bypass setup?
2006 SMB EB45ish.
5.4L, QuadVan 4x4
Ready to Rumble!
Old 02-27-2017, 03:38 PM   #19
I looked into it. They don't offer anything "off-the-shelf" that fits. They did say they could put together a kit that would work, but the cost was far more expensive than the parts I put together. I'm not sure if it would be worth the extra investment.
Old 02-27-2017, 03:46 PM   #20
Glider's Avatar
That makes sense. It sounds like you have a good solution worked out.
2006 SMB EB45ish.
5.4L, QuadVan 4x4
Ready to Rumble!
