Old 09-14-2009, 12:51 AM   #11
Re: Output Shaft on E350 transmission good for 4x4?
My wheelbase is almost 2" longer due to a rear spring upgrade. And it sits about 3" higher than stock. The stock drive shaft is fine. I was worried at first, but so far so good.
Old 09-14-2009, 08:10 PM   #12
panion's Avatar
My 2001 7.3 van has the 4r100. I opted for a shaft change and transmission rebuild at the same time. The adapter for a ford transfer case is an easy find. Atlas I don't know. Keep in mind the speedo sensor is in the stock tailcone so an adapter will be required.
Tom
2001 RB 7.3 Powerstroke 4WD.
https://sportsmobile4x4.blogspot.com/
panion is offline   Reply With Quote
Old 09-14-2009, 08:34 PM   #13
I would also try to use the standard ford adapter to the transfer case. the quigley adapter is 13 in long pushes the transfer case back rather far. also the 4r100 tranny has a electronic speed sensor in the tail housing make sure you use the correct shaft and 4x4 tail housing with the speed sensor hole in it. Hope this helps Dave
unimogdave is offline   Reply With Quote
Old 09-15-2009, 12:32 AM   #14
luked's Avatar
Dave, where can I get the ford adapter?
Also, when you say that i need t make sure to use the correct shaft and tail housing, is this only if I don;t use the adapter? I am a little confused, sorry
Thanks for all the info
Luke
Home Built Camper Van - 2003 EB 15 Passenger, 7.3 PSD, Ujoint 6" Lift, 35x12.50x17E BFG AT KO2 , MSD High Top, Hand Made Interior
luked is offline   Reply With Quote
Old 09-15-2009, 05:39 AM   #15
UJOINT's Avatar
He's just saying to make sure the new adaptor has the proper attachment for the speedo cable/etc. At this point, your best bet is to start shopping the local tranny shops & tell them what you plan to do. They can provide the parts and do the swap. Try to find a shop that is actually a little enthusiastic about it, some can be a real pain if they feel they're "doing you a favor" ---Chris
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
Old 09-23-2010, 05:41 PM   #16
I just bought and received a used 4x4 extension housing for my 4R75W from Whatever it Takes Transmission (found it online). Only $33 plus reasonable shipping and it looks like it's in great shape. They have a few more too.
I'm not sure what tranny you have but here is the link to the extension housing, hope it helps and keeps your costs down on the build:
http://www.wittrans.com/c-724-Ford.aspx?pagenum=38
Part number: RF-F2TP-7A040-BA
U76770B Extension Housing, AOD/AODE 4X4 (6 3/8" Long)(Aluminum) (With 2 Threaded Bosses For Shifter)(Cast # RF-F67P-7A040-AA) $33.38
U76770BA Extension Housing, AOD/AODE 4X4 (6 3/8" Long)(Aluminum) (With 1 Threaded Boss For Shifter) $33.03
U76770BC Extension Housing, AODE/4R70W 4X4 (6 3/8" Long)(Aluminum) (With 2 Threaded Bosses Threaded Bosses For Shifter)(Cast # RF-F2TP-7A040-BA Or RF-3L3P-7A040-AB) $33.38
Also, found the 4x4 output shaft on eBay for $55 and it looks almost new.
05Vanimal is offline   Reply With Quote
Old 09-24-2010, 09:54 PM   #17
Bones_GSXR's Avatar
I have a Quigley (2001 E250) that I just changed to a Ujoint Offroad kit. I liked the Quigley adapter as my Front driveshaft could be longer. I would try to find a F350 Trans and just swap the whole thing in transfer case and all. I have found a few Quigley vans in Salvage yards in the Lower 48and could relay them to you but untill you know what year Van you end up with...
Old 12-26-2010, 07:52 PM   #18
Im doing a 4X4 conversion on my service E350 van with a 7.3 D I can buy trans and transfercase from a F350 for $1200.00 I can get these all the time i have a couple guys that buy wrecked F250 F350 Superdutys and part them out , cheap it cost me 2400.00 for all the drive tran - lift kit .
Chimneyman is offline   Reply With Quote
