Old 08-01-2015, 01:54 AM   #11
neeemo's Avatar
Re: Powder Coating Leaf Springs?
Excellent contribution. Thanks
I wonder if this stuff would work: http://pages.ebay.com/link/?nav=item.vi ... ID=EBAY-US
Z
'02 SMB EB Q 4x4 Diesel
neeemo is offline   Reply With Quote
Old 08-01-2015, 07:51 AM   #12
Originally Posted by LenS
Do not know about leaf springs, would guess (WAG) that they would be lower stressed then coil springs.
I'm working on design at work presently where we are designing tiny leaf springs to hold test tubes (vacutainers)....pretty much the same issues as coil spring design, as you drive the rate lower, the stress increases. The math for leaf springs is the same as beams, either cantilevered or simply supported.
Old 08-01-2015, 08:01 AM   #13
Tapatio's Avatar
This stuff
http://www.amsoil.com/shop/by-produc...tal-protector/
Callsign KK6GIY
Old 08-01-2015, 08:08 AM   #14
powder coating would imply removing them? Why not just wire brush off the scale and spray them with Eastwood rust encapsulator and then follow with black spray paint or their chassis black.
2011 VW TDI Golf for hwy fun
Old 08-01-2015, 02:07 PM   #15
Why not just spray them down with Fluid Film or por-15? Just keep it away from the brakes.
Old 08-04-2015, 07:52 PM   #16
Bbasso's Avatar
I would take them apart, media blasted then simply spray painted with epoxy and then reassemble it and installed you might have to do this every couple of years but it would be inexpensive and relatively easy.
The reason I would go the inexpensive route is because they flex so much. An expensive coating might not be able to keep up with the flexibility and peel or flake off after time. Once you remove the rust by media blasting them and sealing them up with an epoxy paint I doubt they would rust quickly unless the paint was broken where moisture could get in.
Rob.
Current:
And had three other E350s...
Old 09-24-2015, 09:52 AM   #17
The folks at Ken Imler Diesel(big diesel shop in Sacramento) are recommending replacing my leaf springs because of rust. Can the rust be treated with one of the suggestions here or is it just better in the long run to replace them?
James
Sacramento, Ca
'06 E-350 RB-50 6.0 PSD 4x4
jfgarberiv is offline   Reply With Quote
Old 09-24-2015, 11:11 AM   #18
Pntyrmvr's Avatar
Hi James,
I live in an area known for rusty vehicles where the winter road salt is strong enough to kill roadside trees over time.
I have never considered replacing leaf springs because of rust.
Save your money for the engine!
Regards,
Gavin
Old 09-24-2015, 11:14 AM   #19
Agreed. Every vehicle up here (Alberta) looks like that after a year or two. Rusty leaf springs aren't really a concern IMHO. More of an annoyance if they start squeaking.
ert01 is offline   Reply With Quote
Old 09-24-2015, 11:51 AM   #20
Me neither......they would have to be mighty rusty.
