Re: Quigley refresh - suggestions?
There two sets of two bushings associated with the older Ford style swaybar - the two that are bolted to the frame and support the swaybar and the two that are located in the axle.
The two bolted to the frame are easily replaced by unbolting them, sliding the steel U-bracket off and removing the bushings from the swaybar.
The two bushings in the axle assembly are one piece, including the metal sleeve that the rubber is captured in. These are simply "pressed" in the axle assembly - correctly, from front to back. You can just pound them out with a big hammer and drift. In the shop we use an air-hammer.
I have seen some 4x4 conversions where the bushings were tack welded in, so if you are having problems, look for that.
It is an easy replacement...
AgileOffRoad.com
