Re: Quigley Steering Stabilizer/Damper
I know, I know.... Didn't take any pictures during installation. But, really nothing fancy here. First off, it is not 100%, but WAY better then before. Even with the dual stabilizer setup I had. As far as the brackets, Roadmaster wanted something like $120 for them. Way too much!! I live sort of in the boonies and the nearest steel shop is over an hour away so I ended up making do with what I had on hand. I started with 4" x 4" x 1/4" angle. I cut one leg off to 2-1/2" and left the other at 4". drilled holes in the 4" leg for the U-bolts and a single hole in the 2-1/2" side the same diameter as the bushings on the end of the shock. Found the U-bolts at the local Ace hardware. I can try some photos tomorrow if it would help. I can't see where a store bought bracket can be any better. Mine's stronger then hell. Way over built.
So, I'm out around $170 for this setup and much happier then before. And yes, I'd do it again. It really does make the rig easier to drive.
Scatter
2007 RB50, 6.0
K1WGB
