Old 03-02-2012, 05:36 PM   #1
Quigley Van spare tire carrier for 33's question
This is my first post
Ok so i looked on the forum and i saw people talking of them but didn't give me the manufactures. I need a spare tire carrier for a 33" tire, I put on a reciever hitch and now the tire won't fit under the vehicle (not happy). I have seen some nice ones on here and i would like to mount it on the left and still be able to open the right side door. Any suggestions or manufactures would help, maybe even a link. Thanks
mm300zx is offline   Reply With Quote
Old 03-02-2012, 05:59 PM   #2
Roonie's Avatar
Re: Quigley Van spare tire carrier for 33's question
Welcome.
Aluminess does all the Sportsmobile spare tire carriers and bumpers. I have met them and they are friendly folk.
http://www.aluminess.com/
Old 03-02-2012, 06:14 PM   #3
Idon't really want to buy a whole new bumper but if i have to i will. Is the any company that just makes the tire mount? Or is there a company that makes a receiver hitch with enough clearance for a bigger tire?
Old 03-02-2012, 06:20 PM   #4
They make one that fits with a stock bumper.
I have one.
SOLD04 EB350 Custom Floorplan
6.0 PSD 4.10 Posi
Salem Kroger coil spring 4wd
2015 VW GTI
Leaving CA for WA
Old 03-02-2012, 06:34 PM   #5
I have a Westen Bumper I will keep searching
Old 03-03-2012, 03:22 PM   #6
Call Aluminess, they might be able to fab up something to fit.
Old 03-03-2012, 03:27 PM   #7
I have an aftermarket bumper. The Aluminess tire carrier mounts between the bumper brackets and frame. It includes a spacer for the other side so the bumper is still straight. You should try and look at one and see if it will work for you.
On the other hand, I am running 33" tires (275/70-18) and they fit in the factory receiver hitch. I did have to bend the two tabs that are on the front end of the spare, but the 33" spare fit. Later I bought the Aluminess tire carrier and moved the spare out back.
6.0 PSD 4.10 Posi
2015 VW GTI
Leaving CA for WA
Old 03-03-2012, 11:26 PM   #8
I recently picked up my SMB (2WD passenger van conversion). SMB West put the spare on the back (245/16) on an Aluminess carrier. It is a very sturdy carrier, much better than the ones attached to the door. I have a stock bumper with back up sensors in it. Only problem is that the tire sets off the back up alarm. SMB suggested I take it to Ford Dealer to see if they could disconnect the sensors under the tire. Havent been to the dealer yet. Two sensors are about 3 inches below the tire, not actually blocked by the tire. I would like to keep the alarm system in operation all across the back bumper. It was handy before I had the SMB conversion. Anyone have suggestions?
John
johnolden is offline   Reply With Quote
Old 03-04-2012, 12:28 PM   #9
There are tire carriers out there that'll fit in a trailer hitch. The problem is that if on the back they don't swing out of the way. But if you have a front receiver you could mount one tugboat-style there, but watch out that you still get good air to the radiator.
In a similar vein, anyone got ideas to make a swiveling mount for the trailer hitch? I figured I could bend and weld together something to fit in the hitch but I'm stuck for ideas on the swivel part. I actually need to carry four car tires back there in a HF cargo carrier, and I'd still like access to the back right door.
Rob
Old 03-07-2012, 07:56 PM   #10
There is a carrier that fits in the hitch and swings out.
Check this out maybe it will give you an idea
http://www.pickupspecialties.com/Tire_g ... _gate.html
I am going to try and fab something up this spring also, I'll never get away with spending $7-800
on a tire carrier.
If you build something I'd like to see it.
bkroll is offline   Reply With Quote
Serenity
Makalu1
Yeti
ACTNPKRYETI
