[quote="Gnarvan"]I went down to NW Quadvan in Portland this afternoon and had a long talk with John. John took the time to explain all the issues with upgrading my Dana 60's. He seemed to think the odds were pretty good that I had a 35 spline axle. Something about Dana using 35 splined axles on pretty much all their stuff till around 2004 when they came out with the semi-floating setup.
The only way to make sure is to pull one of the axles out and count the splines. Even if they are 32 splined axles he has heavy duty replacement 35 spline axles available. He talked me back into a Detroit True trac for both front and rear, which is what I originally wanted prior to deciding on an e-locker front.
The only serious issue he could think of that could give me grief is if I had one of the Dana 60 front axle housings that have Dana 50 guts in them.
Now all I need to do is find the money to make the change.
NW Quadvan had 3 vans up on the lift when I was down there. They also had a pile of Aluminess stuff for me to drool over. John really helped me understand what I needed to do to make the change. I'm going to enjoy doing business with these folks.
[/quote
Good luck with your van, I hope it goes well for you. One thing you will have to
determine is if your van has a Dana 60 or a Dana 44 in front. Advanced 4x4 is
famous for using a Dana 44 up front. Whatever front axle you have it will be
something odd and probably not an axle that was intended for a Ford.
