Old 11-09-2011, 10:00 AM   #1
REAR FENDER WELL TRIMMING
What are you guys doing on the rear fender well when the 35" tires are rubbing. I know the bushwacker fender flares prevent mud fling but my tires are rubbing on the back portion of the wheel well body. If I get the bush wackers does it open the wheel well bigger than stock ?
I don't mind trimming the the body however I want to see what someone else has done. I was thinking an F350 truck factory fender flare might work.
The front is fine, only rear rubs
Thanks for the help
Toolman is offline   Reply With Quote
Ford
fabtechmfg
Big Grey
allenl
