Old 08-21-2008, 10:05 AM   #1
Rotor Stud Holes
Ok, so i did a bunch of searching here and read something about how the SMB uses stock F350 Rotors , but they need to be drilled out to fit over our larger studs? Is this true?
And if i go buy the rotors from Dynatrac instead of Ford will the holes be drilled out already? (since they use them on their axles)
I really don't feel like having to drill out rotor stud holes.
Our rig is a 2003 SMB with a pro-roc 60 and premium warn hubs. Thanks guys
Dave and Yoshi [Ki6LBB]
https://www.adventureduo.com
Tread Lightly! Trainer
Pack it in Pack it Out>>>> https://www.trasharoo.com
Old 08-21-2008, 11:56 AM   #2
I would love to have over sized rotors calipers and pads but I would have to change eight wheels and tires so I went with a rotor/pad upgrade There could be better out there but these work well for me. Way less brake fade. My van is 12K+ and pull a SMB trailer often. All I can say is so far so good. My next move will be to upgrade the brake lines to braided stainless steel lines.
http://thebrakeman.com/home
Dave B
Old 08-21-2008, 12:18 PM   #3
Ok, just got off the phone with dynatrac. You do in fact have to open up the holes on the stock F350 rotors to 7/8".
Just wanted to confirm i did. Thanks guys.
Old 08-22-2008, 10:39 AM   #4
So your saying if I need a rotor for my front pro rock 60 axle (or the full floating rear axle) and I'm somewhere that only has stock Ford rotors, someone will have to drill them out?
That would be something to know for sure!
If that a fact, I better get back my old rotors from a friend I gave him for his Ford pickup. They won't work.
Dave B
Old 08-22-2008, 11:20 AM   #5
Dave B
Yep, thats why i figured more people would respond to this post. It's kind of important. It's only the front axle that has to be drilled out. And its not that much just a little taken out. Not like your drilling holes into the rotor, you're really just opening it up a hair.
Old 08-22-2008, 06:29 PM   #6
charlie56's Avatar
Re: Rotor Stud Holes
Did you investigate F450 rotors. SMB uses the F450 on the '08's
... Charlie
KZ6T
Old 08-23-2008, 11:04 AM   #7
I did not. Sorry.
Old 08-25-2008, 06:23 PM   #8
Charlie I think 450 rotors are a hole nuther ball game. SMB told me the stock 350 parts would all go back??? This goes for brake pads, and lines....I hope. Man what if you lost a line in the middle of nowhere. Sorry I gave away my old rotors.
Dave B
