Old 04-07-2011, 11:59 AM   #11
Re: Shock part #s for my 2004 SMB 4x4? (Bilstein/Rancho?)
I have Rancho 9000's and they suck. Not nearly enough rebound resistance.
Desert Solitaire
2003 7.3L EB 4x4
Denver Fleet 4x4 conversion
Old 04-07-2011, 12:07 PM   #12
geoffff's Avatar
Thanks -- Yes, I'm coming to understand that is the problem with the Ranchos.
So, I should go with Bilsteins. Can anyone share what models of Bilsteins you're using on your Sportsmobile-conversion 4x4? Or should I try contacting Bilstein or Sportsmobile?
-- Geoff
2004 Ford, SMB 4x4, RB-50
http://octopup.org/sportsmobile
Old 04-07-2011, 12:18 PM   #13
Contact Shane Casad at Bilstien for the correct shocks. He seems to know about SMBs.
Shane.Casad@thyssenkrupp.com
SOLD04 EB350 Custom Floorplan
6.0 PSD 4.10 Posi
Salem Kroger coil spring 4wd
2015 VW GTI
Leaving CA for WA
Old 04-13-2011, 05:51 PM   #14
geoffff's Avatar
Somehow I didn't see that deminimis already posted the answer to my question.
Anyway, for a 2004 converted to 4x4 by Sportsmobile, the recommended Bilsteins are 1720-HO (fronts) and 1614-HO (rears). Sportsmobile also sells custom-valved Old Man Emu shocks for about $100 each.
I wasn't able to get a reply from Shane.Casad@thyssenkrupp.com
-- Geoff
Old 04-13-2011, 10:56 PM   #15
So is Bilstein owned by Thyssen Krupp, an elevator company? Interesting. I'll have to pay more attention to the ride next time I'm in one of their elevators.
Old 04-15-2011, 11:41 AM   #16
Pay more attention by jumping.
Would that be different for a Deaver converted? I'd imagine the length is different.
Also, merging with sticky thread.
and then
everything changed
Old 04-16-2011, 11:36 AM   #17
Yes, the Deaver spring pack/Bilstein shocks are valved and specific to Deaver's specs from what Jeff at Deaver told me. I guess I need to find out those numbers.
Dave
daveb is online now   Reply With Quote
Old 05-13-2011, 12:43 PM   #18
Re: SMB 4WD Parts Reference Thread
For my 2001 SMB 4x4, after a bit of researching, I ordered the following Bilstein Shocks:
Front F4-B46-1720-H1
Rear F4-BE5-E074-HO
They both bolted up, with the exception of the lower shock mount. The thickness of the lower shock mount on the Bilsteins was about 1mm too thick, so I had to grind it down to make it fit, but no harm, no foul.
Pete is offline   Reply With Quote
Old 08-29-2013, 10:45 AM   #19
REF
REF's Avatar
Send a message via MSN to REF
Shock numbers are for my '03 7.3L Quigley SMB, I have an '03 F-350 front end with Deaver rear leaf springs. Also of note, supposedly I have the heavy duty set of front coils that were spec'd out for fleet/ambulance use by Quigley, I think that helps overall with the ride and not hitting the bump stops so much that seems to be so common, also helps with that heavy diesel being up there. When I ordered up my set back in '09, I was told by the custom app guy at Bilstein that the valving on these off the shelf shocks was the same as what they would do on a custom set of 7100 series for me, except that I did not have to convert the stud to eye on the top, thus loosing what valuable travel I had, hence why I went with these. I am now looking at just replacing the aged skyjacker steering damper with a Bilstein unit that was not available at the time, I think I have the right part number for that....
Another note, I had Rancho 9000 adjustable shocks on the rig for a bit before yanking them, they were terrible!! Very happy with my setup now
Front Shock: Bilstein 5100 series (old number):F4-BE5-6243-H5 (Ford Bronco/F-150 w/4" lift)
(new number):24-185523
Rear Shock: Bilstein F-Series Motorhome (old number):F4-BE5-EO74-HO (yellow body)
(new number):33-186863 B6(C)=comfort
Alternate option,stiffer:33-186900 B6(HD)=heavy duty
Steering Stabilizer: Bilstein 24-158848 ('99-'04 F-350,F-450,F-550)
EDIT: the above stabilizer is for a 4X4 but did not fit my centerlink bracket, it has a cantilevered angle piece on one end. I am ordering up Bilstein 24-158930 that has regular eyelets on both ends, like the one that is on there now, check yours, I guess I should have looked at mine more closely.
EDIT#2-Bilstein 33-170794 is now on its way, 3 times a charm!! Has the 46mm body,eye to eye,14.7" compressed/23.6"extended, hope this one will do it.This one works!
Old 04-16-2016, 01:07 PM   #20
For those replacing or wanting to have a spare for long trips the part #s for D60 axle u-joints have changed. According to the Dana/Spicer website (The Expert - Information for driveshafts, u-joints, brakes, axles, heavy axles, light axles )
5-332x is obsolete superceded by SPL55-3x
This is the non-greaseable "Spicer life series".
2011 VW TDI Golf for hwy fun
