Re: Smoking Brakes on a Sportsmobile?
Keep in mind that when and if you decide to upgrade anything other that pads, you might run into compatibility issues, it might not be just a simple swap. For example, on my 03 quigley, I am looking to upgrade my front rotors to cryo power slots (w/hawk pads) as I find the stocks fairly weak, I have to modify the studs on any new rotor I get to fit my bolt pattern. My front end is from an 03 F-350, in stock form is 8X170, the vans rear is 8X6.5, so Quigley modified the studs on the front rotors to match the rears 8X6.5. P.I.T.A. One more check next to the box that says "dynatrack front axle swap"
