I'll 2nd skoronesa on tirechains.com. I ran some of their diamond pattern chains with the boron alloy steel on a 2wd class C chasing snow here in Colorado. Putting on any chain is a PITA, but these went on and off reasonably fast and have a built in tensioner. I liked the diamond pattern for lateral stability, and they are supposed to smooth out the ride a little compared to ladder chains. I'd put them on in the evening if I was expecting overnight snow.
Although I haven't used them on my van, I have run a set of Nokian Hakkapalitta LT2 studded snows on my truck. They're load range E and a damn good tire, but pricy. You can get them without studs as well. I've run Cooper discoverers M+S without studds on a jeep. I thought the rubber was too stiff for a snow tire, but they didnt wear so fast because of it. I suspect they might really need the studs to work well, plus that jeep was so light by comparison maybe it's not applicable here.
