Old 05-23-2012, 04:55 PM   #1
Zeta's Avatar
Spring Plate Fix
Had the broken upper springplate welded with some gussets added for strength. Also welded the two plates that make up the assembly together--basically welded the crap out of it.
Made the same mods to the other side to prevent future breakage. If these break again, fingers may have to be pointed at the driver.
Z
'06 RB50 SMB Diesel
http://www.tomsinclair.net
Old 05-23-2012, 07:05 PM   #2
Railvan's Avatar
Re: Spring Plate Fix
Shortly after the Badgers had one of these plates break on their van I was at SMB west for some work and asked about the new improved design. They showed it to me and gave me two of them for free. I have yet to install them as I had not had any trouble yet with the original ones.
http://www.pbase.com/railvan
2006 Ford RB, 6.0 diesel, SMB 4x4, RB50
Railvan is offline   Reply With Quote
Old 05-24-2012, 01:09 AM   #3
Zeta's Avatar
Spring Plate Fix
Bigvans wrote:
"I have personally held three [broken] of those (One old style and two new style) in my hand from different friends SMBís.
Hopefully mine are better than the "new" versions.
Z
Http://www.tomsinclair.net
'06 RB50 SMB Diesel
Old 05-25-2012, 05:45 PM   #4
BIGVANS's Avatar
Nice Job! They look great!
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 06-04-2012, 10:19 PM   #5
Zeta are you Tom Sinclair photography
cowboy4x4 is offline   Reply With Quote
