Finally getting around to this.
Has anyone installed this setup on a Quigley 4x4?
Like the prior poster with the SMB 4x4, I'm concerned the steering link will hit it. The vertical gap between the steering link and the bracket is about 1/2-3/4" smaller than the suspension travel between the axle and the frame.
I find it hard to believe that the Quigley or SMB steering link would be appreciably further forward or aft from the factory 2WD setup.
I could relocate the bracket 1/2" further forward, but I don't think I can get a drill in there to drill 3 new holes without removing the radiator shroud which is not going to happen, and also it looks like it still wouldn't clear.
Sportsmobile-less.
