02-22-2016, 11:38 AM
#111
What solution did you use to get your side door to clear the tire?
Originally Posted by maxacceleration
Here is my wheel setup on my 4" lifted QuadVan. 17x8.5 Walker Evans street locks with Toyo E rated (80 psi) MT tires, 295/70R17 measuring 33.5". I went up from 285/70R17 Nittos that measured 33.0".
This necessitated a change to 4.56 (from 4.10's) to pull top gear consistently with my V10.
17" wheels to clear F450 brakes. Air bags out back to adjust ride height and compensate for pulling trailers. I did have to trim my front plastic valance for the 295's.
I will be going to Toyo Open Country R/T 295's next as I am below 50% on these tires.
The Toyo Mt's have been good tires.
My previous Nitto 285 tires would not stay balanced for some reason - I had to have them rebalanced several times...
Cheers
AgileOffRoad.com
02-22-2016, 06:32 PM
#112
At 2010, Bushwacker was making fender flares for both swing open side doors & the sliding door.
My sliding door flare is considerably narrower than the drivers side, looking from the rear, allowing the needed clearance.
I understand the sliding door flares have been discontinued.
Thats how it fits.
02-23-2016, 07:22 AM
#113
I'm aware of the narrower Bushwacker Flare for sliding doors, but was really more interested in how the door clears the tire. I've never seen a stock slider clear a tire as big as yours.
You also have an F250/350 SuperDuty front axle with 8 on 170mm metric wheel pattern which would suggest a wheel adapter on the rear axle to convert it from 8 on 6.5" to match and that would make it even wider in the rear.
Does the door hit the tire before fully opening or has the door mechanism been modified? QuadVan offers a modified door mechanism, perhaps you have one.
This is a common problem that prevents people with sliding side doors to use bigger tires and I am wondering what solution your van has.
AgileOffRoad.com
02-23-2016, 10:30 AM
#114
Six years after my van build details are a little foggy. Yes I have 2" spacers at the rear wheels. I think I have the door extension also, but I am not positive on that as I don't remember the stock configuration.
With my door slid all the way back and locked in I have 1/2 - 3/4" of clearance
to the flare.
We love our slider door, and it has been beneficial many times where we could not have opened swing doors. It works to our layout also.
Funny thing, we have never/not yet seen another 4x4 van with a sliding side door.
Dare to be different!
02-23-2016, 10:41 AM
#115
Well, it only makes sense then that you have the QuadVan modification.
Very nice van by the way!
AgileOffRoad.com
02-23-2016, 10:57 AM
#116
Thanks! It works well for us.
02-24-2016, 10:17 AM
#117
Here are a couple of sets we sent out recently:
Method Mesh wrapped in Toyo.
Method Hole wrapped in BFG.
AgileOffRoad.com
02-24-2016, 10:45 AM
#118
FYI I have an MG modified slider door extension on my 4x4 van. Have the 2 inch spacers on the rear axle and the door clears no problem with the stock size small tires.
02-24-2016, 11:19 AM
#119
Love this thread. The sheer number of possible permutations continues to fuel the conversation. Ramsey, those Method Hole Wheels combined with the BFG AT/KO2 look like they belong on the next Mars Rover! Great combo... Is there an image of the whole van wearing those shoes?
George ><>
2005 5.4L E250 RB50 4x4 SMB
2000 4Runner Limited 4WD
But God demonstrates his own love for us in this: While we were still sinners, Christ died for us. Romans 5:8
02-24-2016, 12:11 PM
#120
I'll add to the string of Method wheels... just picked these up for our van this week
Wheels: Method Race Wheels "Standard", 18x9, -12mm offset, machined finish
Tires: Toyo Open Country R/T size LT285/75R18 (34.8" tall x 11" wide)
Why 6? I'm designing a rear bumper with multi-use swing arms so to showcase its ability to hold two spares, I got two extra tires/wheels.
