Old 03-15-2016, 09:29 AM   #131
illking's Avatar
Send a message via AIM to illking
Originally Posted by Abitibi View Post
Those Holes, best looking so far and Toyo's will be the combo I'm going with. I might try the grayish ones instead of the black ones though...
Agreed, Method Hole's are super good looking
www.thevanpires.com
2001 E250 RB30 Agile 4x4
1976 G30 Pathfinder 4x4 SOLD
illking is offline   Reply With Quote
Old 03-15-2016, 03:18 PM   #132
My favorite three are the Method Mesh, ATX Cornice, and ATX Ledge.
2011 VW TDI Golf for hwy fun
Old 05-01-2016, 05:29 PM   #133
I'm looking to upgrade my tires and wheels. But unlike most here I am not looking to raise my stock Van or convert to 4x4. I wish to make this build a total comfort cruiser for the coast hwy.
To that end I would like to lower the tire profile for less wheel roll. I was thinking of a plus 2 configuration with 245/55r18 tires.
Unfortunate I haven't been able to find compatible rims that the websites say are compatible. Either the website does not recognize E series or econoline as valid models or doesn't list anything beyond the standard 16" rim.
By the way I'm looking to mount these on a 1998 E250 ext cargo
My searches have come up with these specs. Stock rims are 16x8 with an 8x6.5 bolt
pattern and zero offset.
I like the look of these even though they are stated as off-road. http://www.fueloffroad.com/hostage-d531-w-6063.htm
They show an 18x9 in three offsets a 1 a -12 and a 20
Has anyone used a 18" rim or have any suggestions? Thank you in advance for your time.
1998f250convert is offline   Reply With Quote
Old 05-04-2016, 10:58 AM   #134
My take on this is that you will actually make your van less comfortable to cruise in. Road imperfections will be more easily felt and heard with a lower profile tire and a bigger, heavier wheel.
However, the handling may be improved with the shorter sidewall.
I recently upgraded my tires and wheels, but kept the same 16" diameter wheel (8" wide instead of stock 6.5"). The tires were bridgestone transforce 245 75/16s and I changed them out for BFG K02s in 265 75/16. Since that change, my van is much smoother and more comfortable, despite the tires now being A/Ts instead of all-seasons. Road joints/imperfections are much more muted now. Even with the taller sidewall, handling has remained the same (cornering) - if anything it has improved.
Just my 2 cents.
capn
capnkurt is offline   Reply With Quote
Old 05-04-2016, 11:19 AM   #135
ctb
ctb's Avatar
Send a message via AIM to ctb
I say, call Jon at Quadvan, Portland, OR and talk with him...he owns a 350Econoline (4x4) and would help you find what you need, and possibly be able to get you a good deal...no sales tax in OR too!! There are too many options not to talk to an expert i the field, or who has decked out thousands of 350's over the years! Good luck!
'13 MDX 'BigBlackmobeebs'
'01 Lexus 430 LS 'Luxobeebs
'20 Tacoma TRD OR 'Tacobeebs'
Old 05-04-2016, 11:53 AM   #136
1998 Express 3500
Here's mine with Pro Comp 7069 wheels: Pro Comp Alloy Wheels - Series 7069, 16x8 with 8 on 6.5 Bolt Pattern - Flat Black Machined | 4WheelParts.com
The tires are 265 75/16 K02s.
capn
Old 05-11-2016, 02:26 PM   #137
gnty's Avatar
Originally Posted by BajaSportsmobile View Post
Here are a couple of sets we sent out recently:
Method Mesh wrapped in Toyo.
Method Hole wrapped in BFG.
Any more pictures of these? full van pics?
gnty is offline   Reply With Quote
Old 05-11-2016, 07:23 PM   #138
Jsweezy's Avatar
Originally Posted by maxacceleration View Post
Here is my wheel setup on my 4" lifted QuadVan. 17x8.5 Walker Evans street locks with Toyo E rated (80 psi) MT tires, 295/70R17 measuring 33.5". I went up from 285/70R17 Nittos that measured 33.0".
This necessitated a change to 4.56 (from 4.10's) to pull top gear consistently with my V10.
17" wheels to clear F450 brakes. Air bags out back to adjust ride height and compensate for pulling trailers. I did have to trim my front plastic valance for the 295's.
I will be going to Toyo Open Country R/T 295's next as I am below 50% on these tires.
The Toyo Mt's have been good tires.
My previous Nitto 285 tires would not stay balanced for some reason - I had to have them rebalanced several times...
Cheers
I now know what my van would look like with a slider! Some days I sure wish it had one...
Old 06-03-2016, 11:32 AM   #139
illking's Avatar
Can anyone ID these wheels? Looks like method holes but without the fake bead lock. ATX Mojave?
www.thevanpires.com
Old 06-03-2016, 11:39 AM   #140
alta825's Avatar
Mojaves. Definitely one of the more popular smb specs over the yrs
Sent from my SAMSUNG-SM-G890A using Tapatalk
2002 EB51 7.3L w/ Stage 2- UJoint 6" 4x4 Conversion
2001 RB50 V10 Quigley- SOLD
alta825 is offline   Reply With Quote
