Old 08-21-2011, 05:26 PM   #1
Zeta's Avatar
Tire Chains
Looking at some tire chains for my rig. 315/75/16 35" tires. RUD doesn't seem to make any in that size. I looked at Clothiers, but they would be over $500 and weigh--get this--46 pounds each! I'm not sure an old fat guy w/ bad shoulders can lift 46 pounds much less muscle them onto four tires. Lots of swearing may help though--which I can provide.
What are other SMB'ers using?
Z
'06 RB50 SMB Diesel
http://www.tomsinclair.net
Old 08-21-2011, 07:29 PM   #2
Re: Tire Chains
Z
RUD chains here. They are easy to install with a bit of practice. Only needed them once in 4 years, but that one time was worth every penny spent to buy them.
R
2006 SMB 4x4, EB-51, 6.0psd
EMrider is offline   Reply With Quote
Old 08-22-2011, 08:18 AM   #3
Re: Tire Chains
I only got chains because sometimes in Yosemite they won't let you in the park if you don't have chains. So, I rarely, if ever use them, but I have them.
SCC Z cable chains. And they list 3 different styles for your size.
SOLD04 EB350 Custom Floorplan
6.0 PSD 4.10 Posi
Salem Kroger coil spring 4wd
2015 VW GTI
Leaving CA for WA
Old 08-22-2011, 08:25 AM   #4
ANZAC's Avatar
Re: Tire Chains
You guys do rear wheels only or all four?
Sportsmobile-less.
Old 08-22-2011, 08:50 AM   #5
Viejo's Avatar
Re: Tire Chains
Rear only here.
2002 E350 7.3 PSD
Quigley 4x4, EB50 floorplan
Old 08-22-2011, 06:41 PM   #6
Re: Tire Chains
Unless your front wheelwells are really big or your van is really raised, you will tear up the front wheel wells when you turn right or left.
2008 Ford E-350 Quigley 4x4 V10 Gas - 144,000 miles
Van Weight 7,800 pounds, added one rear leaf to even it out, BFG AT KO LT265/70R17 E Tire press 50psi seems to run best at my van's weight.
Old 08-25-2011, 09:05 AM   #7
Silver350's Avatar
Re: Tire Chains
$500 vs. a $60K vehicle? Really?
Whatever you buy, stay away from the Chinese stuff if you actually plan on using them. My personal preference is Pewag and Trigg. In that order.
Old 08-25-2011, 10:26 AM   #8
dhally's Avatar
Re: Tire Chains
I would pay close attention to silver's advice, since he lives in the Frozen North...
I have used Les Schwab quick-fit chains on our cars with some success. They might be a little light duty for a van, but they sure are easy to install/remove. The ends are color coded so even an idiot can't screw them up.
2009 E250 RB 5.4L "SilVan"
Old 08-25-2011, 11:41 AM   #9
Zeta's Avatar
Re: Tire Chains
Hey pal, that ain't $500 Canadian I'm talking here!
Z
PS: Good point though.
'06 RB50 SMB Diesel
Old 08-25-2011, 12:22 PM   #10
Pntyrmvr's Avatar
Re: Tire Chains
Hi;
Or even $600 US.
How about two chains? One L/F and one R/R to save some dough. Only with front and rear lockers though.
Although I have seen a photo of an Aussie tour bus with one front chain and 2WD. Steering traction I guess.
Regards,
Gavin
