Old 01-07-2009, 08:06 AM   #21
I went from 285/75/16 BFG AT on American Racing Wheels (stock for SMB 4x4) to 305/70/16 Toyo Open Country MT on the same wheels. No problems, fit great, both are 33" spec, but the E range is so much more solid it feels safer.
Will post a full review later, but wanted to chime in on the size thread.
Old 01-07-2009, 10:06 AM   #22
We are running 315/70R17 (35's) BFG All Terrain D rated (3195@50psi) , truck weighs just shy 10,000 lbs fully loaded. We get no rubbing whatsoever. No problem with the 4.10's and the v10. Flat tows our TJ just fine as well.
Dave and Yoshi [Ki6LBB]
https://www.adventureduo.com
Tread Lightly! Trainer
Pack it in Pack it Out>>>> https://www.trasharoo.com
Old 01-07-2009, 12:16 PM   #23
Just and FYI superduty rims are the wrong bolt pattern for SMB converted 4x4.
Old 01-07-2009, 12:30 PM   #24
Yeah, what Jage said.
SMB lug pattern is 8 on 6.5
Super Duty is 8 on 170mm
Old 01-07-2009, 12:31 PM   #25
Greg In Austin's Avatar
I agree with Jage... .stick with E-rated.
We are very happy with out E-rated Cooper STTs (3860lbs) 325/65R18
Greg in Austin
Old 01-07-2009, 01:12 PM   #26
neeemo's Avatar
Does the Quigley also use 8 on 6.5"?
Tom
'02 SMB EB Q 4x4 Diesel
neeemo is offline   Reply With Quote
Old 01-07-2009, 02:00 PM   #27
Yes. All E Series vans from Ford should be 8 on 6.5.
Old 01-07-2009, 02:31 PM   #28
alta825's Avatar
Yes my 01 Quigley has 8/6.5 bolt pattern
-d
2002 EB51 7.3L w/ Stage 2- UJoint 6" 4x4 Conversion
2001 RB50 V10 Quigley- SOLD
alta825 is offline   Reply With Quote
Old 01-07-2009, 04:46 PM   #29
My new Quigley is 8x170 with 17" wheels.
Old 01-07-2009, 05:36 PM   #30
Are you positive? This doesn't make any sense. Anyone else with a 08 confirm this?
Otter
2015 Ford E350
Hondo
