Its alive.... Its Alive...
to revive this old tread, im just NOW getting to new tires... and if swtichfoot is still around, he said
I just would like to clarify Switchfoot, or to check to see if i understand correctly. Switchfoot says that I need LESS backspacing thereby moving the tires out, away from the chassis. I am pretty sure this would cause more rubbing, as I "think" they are too far out now. I just want to make sure. see my two photos, ....
Originally Posted by Switchfoot
Rockman - sounds like you have your rims have too much backspacing if your 285s are rubbing while turning. Your tire needs to be further away from the chassis = less backspacing. You should be able to run those tires just fine. More backspacing pulls the tires in and is easier on the hubs and bearings; but if you can't run the size tires you what, is it worth it?
I'm running 315/70-17s and they don't rub while turning at all. My rims are Helo Guns (a bit blingy yes) 17"x9", 6 mm offset and 5.25" backspacing.
my backspacing... 4.25
Wheels Unloaded, turned to closest point.
