Old 11-12-2017, 06:17 PM   #1
depark's Avatar
To Block or Not To Block
Hi All,
I have looked all over the interweb and can't seem to find a solid answer. It seems 50/50. Is it a bad idea to to use 4-5" blocks on the rear axle temporally for a 6" suspension upgrade? It would be for about a year until I could save for a new set of springs. I know that axle wrap is a concern but how much? I tow 6000 lbs with a 5.4. The axle would have 4.56's on 35"s. Any recommendations are welcome.
Cheers
Darryl
2006 Ford E250 RB 5.4L gas
Clydesdale 4WD Conversion
VA7DTP
Old 11-12-2017, 06:39 PM   #2
Bbasso's Avatar
Personally I wouldn't.
Because if things broke you'd be spending more on towing and repairs then the springs.
Rob.
Current:
And had three other E350s...
Old 11-13-2017, 10:13 AM   #3
Pntyrmvr's Avatar
How about a shackle flip?
Old 11-13-2017, 10:46 AM   #4
MadScience's Avatar
I'd be more wary of spending money and labor (or DIY time) on an interim state, than of 4" blocks.
Old 11-13-2017, 11:02 AM   #5
MountainBikeRoamer's Avatar
+2
Additionally ---
A rear lift, especially with the extra chassis dynamics and load/torque forces experienced by the rear axle/springs while towing.....this doesn't seem like the place to do anything that's "only half-way to the proper solution" either. JHMO!
By the way --- just reading up about the shackle flip approach to suspension lifting. Seems like a lot of off-road/Jeep/rock-crawler guys really dig it! But I'm also reading some cautions about using it on a vehicle you tow with....not sure exactly what the force-diagrams would indicate, but you are indeed changing the rear shackle from acting as a tension structure to a compression structure.
Mike T
___________________
'95 Ford E250 RB30 PH
Old 11-13-2017, 08:48 PM   #6
Pntyrmvr's Avatar
Not a completely compression structure as the tension portion of the forces would increase as the shackle passes vertical while the spring load increases.
Old 11-13-2017, 08:59 PM   #7
Ah! This is true.
Mike T
___________________
Old 11-13-2017, 09:53 PM   #8
depark's Avatar
Thanks for the responses. It has confirmed what my gut was telling me. No blocks for me. New springs it will be.
Cheers
Darryl
VA7DTP
Old 11-14-2017, 06:32 AM   #9
simplesez's Avatar
The atlas springs from Ujoint are less than half the price of Deaver springs. Get them.
Old 11-15-2017, 09:23 AM   #10
bet on black's Avatar
blocks aren't the ideal solution,but they work fine. i am using ones with loops for the u-bolts to pass though, so no chance of them coming loose.
Ford F-250/350 Fabricated Lift Blocks
'99 ford e350 - 7.3L 4x4
'10 ford f150 raptor scab
'53 buick special eight - the sled
bet on black is offline   Reply With Quote
Velocista
Rocketboy
The YURT
MKRyan
