Old 12-15-2012, 08:05 PM   #1
depark's Avatar
Transfer Case noise question
Just a quick question about my TC. How much noise should be comming from it when decelerating? I went to use it tonight in the snow and it sounded strange when I engaged it. When I accelerate or am under power ir sounds fine. When I let off the gas and slow down it has a noticible noise. I don't remember it from the last time I used it which was during the summer. Just curious if it is something to worry about. Thanks in advance.
Cheers
Darryl
2006 Ford E250 RB 5.4L gas
Clydesdale 4WD Conversion
VA7DTP
Old 12-15-2012, 08:11 PM   #2
Re: Transfer Case noise question
Is it a rattle type noise or kind of a whine? I would disengage and re-engage it and try again. Make sure nothing is laying against one of the sticks.
Old 12-15-2012, 08:37 PM   #3
depark's Avatar
It is more of a whine. I did engage and disengage and tried it a couple of times, no joy. It is not a grinding noise.
VA7DTP
Old 12-15-2012, 10:58 PM   #4
Darryl, mine does make a slight whine where the pitch changes with the RPMs/MPH on downhill grades. I'd go try it again and see if it was fully engaged. I've also had an empty soda bottle touch it and amplify the sound...
Dave
Old 12-15-2012, 11:21 PM   #5
depark's Avatar
Thanks Dave, I will try that tomorrow.
Darryl
VA7DTP
Old 01-08-2013, 12:37 PM   #6
depark's Avatar
I finally found out what the noise was. The front drive shaft bearing in the TC blew up. There is nothing like the mechanic coming to tell you that there are metal shavings in your TC oil. I have to say that when I told the conversion company they stepped up and will get it fixed. They are arranging with a shop in my town to fix it so I don't have to send it back to them. That's what I call Great customer service!
VA7DTP
Old 01-08-2013, 12:47 PM   #7
Gnarvan's Avatar
How many miles were on the Transfer Case? Is there a reason that caused the bearing to fail? Is anything in your drive train causing a vibration that could stress the bearing? Was it leaking oil from any bad seals?
John
Gnarvan 1992 E350 Clubwagon
2003 BMW R1150GS-Adventure
2013 BMW R1200GS-Adventure
Old 01-08-2013, 02:04 PM   #8
I'd like to know if it was an Advanced Adaptors TC.
Glad you found the reason for the noise but I also would like to know why it failed.
Old 01-08-2013, 02:22 PM   #9
His signature shows he has a Clydesdale 4WD Conversion. Does that mean Budweiser 4x4?
Old 01-08-2013, 03:45 PM   #10
depark's Avatar
Good questions. The TC has about 6000 miles on it with extremely light use. No vibrations that I have noticed. The seals are perfect. No oil leaking at all. I will see the parts when I get it fixed next week. I will have more answers then.
VA7DTP
