Old 11-08-2010, 12:11 PM   #1
Transfer case shifting
I would like to know what SMB uses for shifting the transfer case. A description or pics of the underside would be great! Do they use a pre-fabricated kit (Advance Adapter) or is it something custom inhouse? I'm not sure if they use cables, rod linkages, etc. I'm looking at a DIY project and trying to figure out a floor shifting solution for a Chevy NP241 transfer case.
Thanks!
2005 Chevy 1500 AWD
4x4 conversion, Ultralight RB50 floorplan,
Firestone Destination A/T, Silverado wheels, 3000w inverter, PIAA lighting
zuren is offline   Reply With Quote
Old 11-08-2010, 12:43 PM   #2
Roonie's Avatar
Re: Transfer case shifting
A description of what SMB uses and a video to show it.
Old 11-08-2010, 01:54 PM   #3
FYI, Advanced Adapters does also offer a cable shifter for the Atlas transfer case.
Old 11-08-2010, 02:53 PM   #4
There is nothing special under the van, it's just standard linkage for an Atlas T-Case- meaning rods. You should watch some old Monster Garage episodes- Jesse James comes up with some crazy linkages in some of the episodes.
If your DIYing I'd go cable and you can put the shifter anywhere:
http://www.novak-adapt.com/catalog/kit_sk2xr.htm
Old 11-09-2010, 11:23 AM   #5
Thanks! I had never seen an Atlas in action before so that video was perfect. I knew there was a cable add-on but wasn't sure how the SMB vans were specifically set up.
Thanks for the link to the shifter kit. I had looked at that along with a couple other during this process.
2005 Chevy 1500 AWD
LiamMobile
Shyll
MCSporty
MSD
