05-21-2017, 02:28 PM
#21
You don't need one. Spray some PB blaster on the tone ring and carefully pry it loose and then tap the studs out with a BFH. That will separate them unless yours is way different than what I've seen. Tone ring must be removed for the rotor to slip off the back of the hub.
05-21-2017, 08:57 PM
#22
Pulled the passenger side hub today. Will try to get them separated tomorrow.
Sent from my SM-G930V using Tapatalk
2006 EB Transformer
05-21-2017, 09:18 PM
#23
That's the same as the rest I've seen. You can separate them easily.
05-21-2017, 09:27 PM
#24
So do the studs get pressed into the hub or the rotor?
2006 EB Transformer
05-22-2017, 08:03 AM
#25
I'm not exactly sure what you're trying to accomplish but on the old SMBs that I've updated I was changing the rotor to an over the hub style with a different rotor so I pressed the studs into the back of the hub (after removing the old rotor). By 06 I think some things had changed. I think you'll probably still want to ask SMB. What I did required changing of calipers and some light machining on them too, also spacing them to fit the new rotor.
05-22-2017, 09:33 AM
#26
I'm just trying to replace the rotors.
2006 EB Transformer
05-22-2017, 05:32 PM
#27
I think you're about there then. Just put the new rotor on the same way and tap the studs in to get them started, then take your impact and lug nuts and seat the studs completely with it. Much easier than the BFH method.
I have found it tough to get the tone ring back where it was, centered and tight. Don't beat on it, they will break. Just dry all the PBblaster/oil/whatever off it and where it goes and tap it around carefully back into place.
Edit: Your tone ring is different than mine. Mine was on the inside of the hub (a bigger tone ring), yours is on the outside of the smaller part of the hub, so take what I've said with a grain of salt. It probably works the same way and is gently pressed in place but I'm not sure.
05-22-2017, 09:18 PM
#28
Thanks. I dropped the hub off at a shop by my work that will separate the rotor for me for free. Once I measure the stud holes in the old rotor and drill out the new rotor to match, he is going to press the new studs in for me.
2006 EB Transformer
05-23-2017, 10:12 PM
#29
2006 EB Transformer
05-24-2017, 06:55 AM
#30
Glad you got it worked out!
