Old 10-08-2010, 05:10 PM   #21
Re: Twitchy Steering
i have the opposite issue.. mine holds great but there is a LOT of play in the steering so it's kind of odd switching lanes and having to over correct the steering.. any ideas?
racrx451 is offline   Reply With Quote
Old 10-08-2010, 05:25 PM   #22
How old is the van? Has it always done it, or is it getting worse? Is the play the same throughout the range of the steering box, or is it worse in the middle of the steering?
Could be an old, worn out steering box. Could be the crossshaft adjuster is too loose.
Old 10-10-2010, 10:00 PM   #23
the van is a 2000. Ive only had it for a month and put about 3500 miles on it. it's only in the middle of the steering and it's been that way since i got it.
Old 10-11-2010, 07:12 PM   #24
If the play is only in the middle of the travel, you can either live with it or replace the steering box. If it had play throughout the range of rotation, you might have been able to tighten the cross-shaft clearance.
Old 11-06-2010, 07:49 AM   #25
Your caster is not right when you add weight to the rear the front lifts changing the caster so if you put more caster ( rolling the front axle forward it will make it not over steer you need ajustable upper and lower contol arms for the ease adjusting caster .
Chimneyman is offline   Reply With Quote
